I have logstash v2.3.2 installed and wanted to try the twitter-plugin again after abandoning it earlier in favor for a custom developed twitterstream-client.
Setting the proxy-relevant settings to:
use_proxy => true
proxy_address => "xxx.yyy.zzz"
proxy_port => xxxx
I get loads of the following exceptions when logstash starts:
{:timestamp=>"2016-05-19T13:13:08.304000+0200", :message=>"End of file reached", :exception=>#<EOFError: End of file reached>, :backtrace=>["org/jruby/RubyIO.java:2895:in readpartial'", "E:/twitter/logstash-2.3.2/vendor/bundle/jruby/1.9/gems/logstash-input-twitter-2.2.2/lib/logstash/inputs/twitter/patches.rb:30:instream'", "E:/twitter/logstash-2.3.2/vendor/bundle/jruby/1.9/gems/logstash-input-twitter-2.2.2/lib/logstash/inputs/twitter/patches.rb:58:in request'", "E:/twitter/logstash-2.3.2/vendor/bundle/jruby/1.9/gems/twitter-5.15.0/lib/twitter/streaming/client.rb:37:infilter'", "E:/twitter/logstash-2.3.2/vendor/bundle/jruby/1.9/gems/logstash-input-twitter-2.2.2/lib/logstash/inputs/twitter.rb:128:in run'", "E:/twitter/logstash-2.3.2/vendor/bundle/jruby/1.9/gems/logstash-core-2.3.2-java/lib/logstash/pipeline.rb:342:ininputworker'", "E:/twitter/logstash-2.3.2/vendor/bundle/jruby/1.9/gems/logstash-core-2.3.2-java/lib/logstash/pipeline.rb:336:in `start_input'"], :options=>nil, :level=>:warn}
Now, if I set use_proxy => false logstash starts but of course I get a connection refused error as the twitter-plugin is unable to connect to my proxy which uses https. I guess the plugin defaults to http.
Is this a known problem and is there a workaround?
