Problems in Elasticsearch combining two types of logs using two pipelines (Logstash)
Hi everyone, I need some help.
I have configured my ES stack inside a docker. I need to show two types of logs (syslog, log), in an Elastic index. I have created two configuration files
  • logstash.cong
  • logstash-syslog.conf
I also created two pipelines in logstash to manage the two files. Despite this Elasticsearch always shows only the logs of one of the two and never both together.
Configuration files below
logstash.cong
  beats {
    port => 5044
  tcp {
    port => 5000
    mutate { replace => { "[host]" => "%{[host][name]}" } }
    hosts => "https://elasticsearch:9200"
    user => "user"
    password => "password"
    ecs_compatibility => disabled
    cacert => "config/elasticsearch-ca.pem"
    #index => "%{[@metadata][beat]}-%{[@metadata][version]}-%{+YYYY.MM.dd}"
    index => "my-index"
  tcp {
    port => 5044
    type => syslog
  udp {
    port => 5044
    type => syslog
  if [type] == "syslog" {
    grok {
      match => { "message" => "%{SYSLOGTIMESTAMP:syslog_timestamp} %{SYSLOGHOST:syslog_hostname} %{DATA:syslog_program}(?:\[%{POSINT:syslog_pid}\])?: %{GREEDYDATA:syslog_message}" }
      add_field => [ "received_at", "%{@timestamp}" ]
      add_field => [ "received_from", "%{host}" ]
    date {
      match => [ "syslog_timestamp", "MMM  d HH:mm:ss", "MMM dd HH:mm:ss" ]
    user => "user"
    index => "my-index"
pipelines.yml
- pipeline.id: pipeline_1
  path.config: "/usr/share/logstash/pipeline/logstash.conf"
  pipeline.workers: 3
- pipeline.id: pipeline_2
  path.config: "/usr/share/logstash/pipeline/logstash-syslog.conf"
  queue.type: persisted
How can i report the two types of logs in the elastic index?
Thanks in advance
Can anybody help me?
