Problems to deploy metricbeat in a ECK environment running on Minikube
Hi all.
After installing Minikube in a Ubuntu VM and creating a single Masternode K8s cluster I've been able to deploy ES and Kibana by using the quickstart examples that can be found in Elastic Offitial Documentation.
I've created a 2 Master Nodes + 2 Data Nodes by using the following .yaml
apiVersion: elasticsearch.k8s.elastic.co/v1
kind: Elasticsearch
metadata:
spec:
  version: 8.4.2
  nodeSets:
  - name: master
    count: 2
    config:
      node.roles: master
      node.store.allow_mmap: false
      xpack.monitoring.collection.enabled: true
      xpack.monitoring.elasticsearch.collection.enabled: false
    podTemplate:
      metadata:
        annotations:
          # Para evitar que el log se automonitorice a si mismo y cree logs a partir de lo que ya contienen sus logs. Bucle infinito
          co.elastic.logs/enabled: "false"
  - name: data
    count: 2
    config:
      node.roles: ["data", "ingest", "ml"]
A Kibana with this .yaml
root@ubuntudocker:/elk# vi kibana.yaml
apiVersion: kibana.k8s.elastic.co/v1
kind: Kibana
metadata:
spec:
  version: 8.4.2
  count: 1
  elasticsearchRef:
  http:
    service:
      spec:
        type: LoadBalancer
  config:
    monitoring.kibana.collection.enabled: false
    # Recomendado cuando ES corre en contenedores
    monitoring.ui.container.elasticsearch.enabled: true
  podTemplate:
    metadata:
      annotations:
        co.elastic.logs/fileset: "log" # audit fileset will duplicate all logs
    spec:
      # tolerations (irrelevant if tains are not configured in k8s nodes)
      tolerations:
        - key: "area"
          operator: "Equal"
          value: "monitoring"
          effect: "NoSchedule"
After that, I tried to deploy MetricBeat so I get metrics about the Pods, volumes, etc... contained in my single node cluster of K8s Minikube.
Said that. First thing I did was installing kube-state-metrics. Once it was done, and after forwarding data to the VM Ubuntu --> ** kubectl port-forward svc/kube-state-metrics 30135:8080 -n kube-system &**
I was capable to see metrics with a browser from the Ubuntu VM Server where the Kubernetes container runs: http://localhost:30135/metrics
And I get data like the following:
kube_persistentvolumeclaim_labels{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-master-0"} 1
kube_persistentvolumeclaim_labels{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-master-1"} 1
kube_persistentvolumeclaim_labels{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-data-0"} 1
kube_persistentvolumeclaim_labels{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-data-1"} 1
HELP kube_persistentvolumeclaim_annotations Kubernetes annotations converted to Prometheus labels.
TYPE kube_persistentvolumeclaim_annotations gauge
kube_persistentvolumeclaim_annotations{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-master-0"} 1
kube_persistentvolumeclaim_annotations{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-master-1"} 1
kube_persistentvolumeclaim_annotations{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-data-0"} 1
kube_persistentvolumeclaim_annotations{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-data-1"} 1
HELP kube_persistentvolumeclaim_info [STABLE] Information about persistent volume claim.
TYPE kube_persistentvolumeclaim_info gauge
kube_persistentvolumeclaim_info{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-master-0",storageclass="standard",volumename="pvc-73d68560-097a-4e82-8154-f05023c795eb"} 1
kube_persistentvolumeclaim_info{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-master-1",storageclass="standard",volumename="pvc-b531f768-2e86-4268-abb3-9f4c7820e5cf"} 1
kube_persistentvolumeclaim_info{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-data-0",storageclass="standard",volumename="pvc-344c7f37-b041-4e27-9217-339fe3a437f1"} 1
kube_persistentvolumeclaim_info{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-data-1",storageclass="standard",volumename="pvc-634af398-0ea3-433a-87d5-f571c69d8623"} 1
HELP kube_persistentvolumeclaim_status_phase [STABLE] The phase the persistent volume claim is currently in.
TYPE kube_persistentvolumeclaim_status_phase gauge
kube_persistentvolumeclaim_status_phase{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-data-0",phase="Lost"} 0
kube_persistentvolumeclaim_status_phase{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-data-0",phase="Bound"} 1
kube_persistentvolumeclaim_status_phase{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-data-0",phase="Pending"} 0
kube_persistentvolumeclaim_status_phase{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-data-1",phase="Lost"} 0
kube_persistentvolumeclaim_status_phase{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-data-1",phase="Bound"} 1
kube_persistentvolumeclaim_status_phase{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-data-1",phase="Pending"} 0
kube_persistentvolumeclaim_status_phase{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-master-0",phase="Lost"} 0
kube_persistentvolumeclaim_status_phase{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-master-0",phase="Bound"} 1
kube_persistentvolumeclaim_status_phase{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-master-0",phase="Pending"} 0
kube_persistentvolumeclaim_status_phase{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-master-1",phase="Lost"} 0
kube_persistentvolumeclaim_status_phase{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-master-1",phase="Bound"} 1
kube_persistentvolumeclaim_status_phase{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-master-1",phase="Pending"} 0
HELP kube_persistentvolumeclaim_resource_requests_storage_bytes [STABLE] The capacity of storage requested by the persistent volume claim.
TYPE kube_persistentvolumeclaim_resource_requests_storage_bytes gauge
kube_persistentvolumeclaim_resource_requests_storage_bytes{namespace="default",persistentvolumeclaim="elasticsearch-data-elasticsearch-es-data-1
With kube-state-metrics running and apparently working well I tried to find a 'quickstart' example for metricbeat but despite I've looked in both:
https://www.elastic.co/guide/en/cloud-on-k8s/current/k8s-beat-quickstart.html
and
I've just found examples for Filebeat and Heartbeat but not for Metricbeat.
What I found instead here:
https://www.elastic.co/guide/en/cloud-on-k8s/current/k8s-beat-configuration-examples.html
Is the possibility of creating a whole ES environment that uses the following manifiest:
kubectl apply -f https://raw.githubusercontent.com/elastic/cloud-on-k8s/2.5/config/recipes/beats/metricbeat_hosts.yaml
What I did was downloading that .yaml and extracting the metribeat part from it . Afterwards I applied my metric.yalm resulting file that looked like this:
apiVersion: beat.k8s.elastic.co/v1beta1
kind: Beat
metadata:
spec:
  type: metricbeat
  version: 8.4.2
  elasticsearchRef:
  kibanaRef:
  config:
    metricbeat:
      autodiscover:
        providers:
        - hints:
            default_config: {}
            enabled: "true"
          node: ${NODE_NAME}
          type: kubernetes
      modules:
      - module: system
        period: 10s
        metricsets:
        - cpu
        - load
        - memory
        - network
        - process
        - process_summary
        process:
          include_top_n:
            by_cpu: 5
            by_memory: 5
        processes:
      - module: system
        period: 1m
        metricsets:
        - filesystem
        - fsstat
        processors:
        - drop_event:
            when:
              regexp:
                system:
                  filesystem:
                    mount_point: ^/(sys|cgroup|proc|dev|etc|host|lib)($|/)
      - module: kubernetes
        period: 10s
        node: ${NODE_NAME}
        hosts:
        - https://${NODE_NAME}:10250
        bearer_token_file: /var/run/secrets/kubernetes.io/serviceaccount/token
        ssl:
          verification_mode: none
        metricsets:
        - node
        - system
        - pod
        - container
        - volume
    processors:
    - add_cloud_metadata: {}
    - add_host_metadata: {}
  daemonSet:
    podTemplate:
      spec:
        serviceAccountName: metricbeat
        automountServiceAccountToken: true # some older Beat versions are depending on this settings presence in k8s context
        containers:
        - args:
          - -e
          - -c
          - /etc/beat.yml
          - -system.hostfs=/hostfs
          volumeMounts:
          - mountPath: /hostfs/sys/fs/cgroup
          - mountPath: /var/run/docker.sock
          - mountPath: /hostfs/proc
          env:
          - name: NODE_NAME
            valueFrom:
              fieldRef:
                fieldPath: spec.nodeName
        dnsPolicy: ClusterFirstWithHostNet
        hostNetwork: true # Allows to provide richer host metadata
        securityContext:
          runAsUser: 0
        terminationGracePeriodSeconds: 30
        volumes:
        - hostPath:
            path: /sys/fs/cgroup
        - hostPath:
            path: /var/run/docker.sock
        - hostPath:
            path: /proc
# permissions needed for metricbeat
# source: https://www.elastic.co/guide/en/beats/metricbeat/current/metricbeat-module-kubernetes.html
apiVersion: rbac.authorization.k8s.io/v1
kind: ClusterRole
metadata:
rules:
- apiGroups:
  resources:
  - nodes
  - namespaces
  - events
  - pods
  verbs:
  - get
  - list
  - watch
- apiGroups:
  - "extensions"
  resources:
  - replicasets
  verbs:
  - get
  - list
  - watch
- apiGroups:
  - apps
  resources:
  - statefulsets
  - deployments
  - replicasets
  verbs:
  - get
  - list
  - watch
- apiGroups:
  resources:
  - nodes/stats
  verbs:
  - get
- nonResourceURLs:
  - /metrics
  verbs:
  - get
apiVersion: v1
kind: ServiceAccount
metadata:
  namespace: default
Once it was applied, a new pod ('metricbeat-beat-metricbeat-j68zf' and a new index were created and documents were indexed. But after taking a look in Kibana -> Discover. I can see that I have only recieved documents from (I guess) the system module containing fields like system.cpu.cores or similar, but nothing like kubernetes.something. As you can guess my metricbeat system dashboard represented graphs but those related to Kubernetes remained empty.
I tried to get inside of the metribeat bot
kubectl exec --stdin --tty metricbeat-beat-metricbeat-j68zf -- /bin/bash
And it got me into the /usr/share/metricbeat of my minikube container and the directory /usr/share/metricbeat/logs is empty (I guess this was stupid as I'm new in K8s)
I runned also the -> kubectl logs metricbeat-beat-metricbeat-j68zf
*W1208 17:28:31.714431 7 reflector.go:324] pkg/mod/k8s.io/client-go@v0.23.4/tools/cache/reflector.go:167: failed to list *v1.Node: nodes is forbidden: User "system:serviceaccount:default:metricbeat" cannot list resource "nodes" in API group "" at the cluster scope
E1208 17:28:31.714468 7 reflector.go:138] pkg/mod/k8s.io/client-go@v0.23.4/tools/cache/reflector.go:167: Failed to watch *v1.Node: failed to list *v1.Node: nodes is forbidden: User "system:serviceaccount:default:metricbeat" cannot list resource "nodes" in API group "" at the cluster scope
W1208 17:28:36.683537 7 reflector.go:324] pkg/mod/k8s.io/client-go@v0.23.4/tools/cache/reflector.go:167: failed to list *v1.Node: nodes "minikube" is forbidden: User "system:serviceaccount:default:metricbeat" cannot list resource "nodes" in API group "" at the cluster scope
E1208 17:28:36.683570 7 reflector.go:138] pkg/mod/k8s.io/client-go@v0.23.4/tools/cache/reflector.go:167: Failed to watch *v1.Node: failed to list *v1.Node: nodes "minikube" is forbidden: User "system:serviceaccount:default:metricbeat" cannot list resource "nodes" in API group "" at the cluster scope
{"log.level":"error","@timestamp":"2022-12-08T17:28:36.911Z","log.origin":{"file.name":"module/wrapper.go","file.line":256},"message":"Error fetching data for metricset kubernetes.system: error doing HTTP request to fetch 'system' Metricset data: HTTP error 403 in : 403 Forbidden","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"error","@timestamp":"2022-12-08T17:28:40.056Z","log.origin":{"file.name":"module/wrapper.go","file.line":256},"message":"Error fetching data for metricset kubernetes.volume: error doing HTTP request to fetch 'volume' Metricset data: HTTP error 403 in : 403 Forbidden","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"error","@timestamp":"2022-12-08T17:28:46.909Z","log.origin":{"file.name":"module/wrapper.go","file.line":256},"message":"Error fetching data for metricset kubernetes.system: error doing HTTP request to fetch 'system' Metricset data: HTTP error 403 in : 403 Forbidden","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"error","@timestamp":"2022-12-08T17:28:50.060Z","log.origin":{"file.name":"module/wrapper.go","file.line":256},"message":"Error fetching data for metricset kubernetes.volume: error doing HTTP request to fetch 'volume' Metricset data: HTTP error 403 in : 403 Forbidden","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"info","@timestamp":"2022-12-08T17:28:53.714Z","log.logger":"monitoring","log.origin":{"file.name":"log/log.go","file.line":185},"message":"Non-zero metrics in the last 30s","service.name":"metricbeat","monitoring":{"metrics":{"beat":{"cgroup":{"memory":{"mem":{"usage":{"bytes":-9756672}}}},"cpu":{"system":{"ticks":15180,"time":{"ms":160}},"total":{"ticks":38110,"time":{"ms":270},"value":38110},"user":{"ticks":22930,"time":{"ms":110}}},"handles":{"limit":{"hard":1048576,"soft":1048576},"open":10},"info":{"ephemeral_id":"9b122d95-00b3-4474-bb31-905ef3a85de3","uptime":{"ms":3846001},"version":"8.4.2"},"memstats":{"gc_next":24140080,"memory_alloc":22178544,"memory_total":2153241688,"rss":195506176},"runtime":{"goroutines":119}},"libbeat":{"config":{"module":{"running":0}},"output":{"events":{"acked":66,"active":0,"batches":18,"total":66},"read":{"bytes":16929},"write":{"bytes":87130}},"pipeline":{"clients":13,"events":{"active":0,"published":66,"total":66},"queue":{"acked":66}}},"metricbeat":{"kubernetes":{"system":{"events":3,"failures":3},"volume":{"events":3,"failures":3}},"system":{"cpu":{"events":3,"success":3},"load":{"events":3,"success":3},"memory":{"events":3,"success":3},"network":{"events":42,"success":42},"process":{"events":6,"success":6},"process_summary":{"events":3,"success":3}}},"system":{"load":{"1":0.61,"15":0.91,"5":0.97,"norm":{"1":0.0381,"15":0.0569,"5":0.0606}}}},"ecs.version":"1.6.0"}}
{"log.level":"error","@timestamp":"2022-12-08T17:28:56.909Z","log.origin":{"file.name":"module/wrapper.go","file.line":256},"message":"Error fetching data for metricset kubernetes.system: error doing HTTP request to fetch 'system' Metricset data: HTTP error 403 in : 403 Forbidden","service.name":"metricbeat","ecs.version":"1.6.0"}
W1208 17:28:59.359600 7 reflector.go:324] pkg/mod/k8s.io/client-go@v0.23.4/tools/cache/reflector.go:167: failed to list *v1.Node: nodes "minikube" is forbidden: User "system:serviceaccount:default:metricbeat" cannot list resource "nodes" in API group "" at the cluster scope
E1208 17:28:59.359643 7 reflector.go:138] pkg/mod/k8s.io/client-go@v0.23.4/tools/cache/reflector.go:167: Failed to watch *v1.Node: failed to list *v1.Node: nodes "minikube" is forbidden: User "system:serviceaccount:default:metricbeat" cannot list resource "nodes" in API group "" at the cluster scope
{"log.level":"error","@timestamp":"2022-12-08T17:29:00.059Z","log.origin":{"file.name":"module/wrapper.go","file.line":256},"message":"Error fetching data for metricset kubernetes.volume: error doing HTTP request to fetch 'volume' Metricset data: HTTP error 403 in : 403 Forbidden","service.name":"metricbeat","ecs.version":"1.6.0"}
W1208 17:29:05.603426 7 reflector.go:324] pkg/mod/k8s.io/client-go@v0.23.4/tools/cache/reflector.go:167: failed to list *v1.Node: nodes "minikube" is forbidden: User "system:serviceaccount:default:metricbeat" cannot list resource "nodes" in API group "" at the cluster scope
E1208 17:29:05.603460 7 reflector.go:138] pkg/mod/k8s.io/client-go@v0.23.4/tools/cache/reflector.go:167: Failed to watch *v1.Node: failed to list *v1.Node: nodes "minikube" is forbidden: User "system:serviceaccount:default:metricbeat" cannot list resource "nodes" in API group "" at the cluster scope
{"log.level":"error","@timestamp":"2022-12-08T17:29:06.909Z","log.origin":{"file.name":"module/wrapper.go","file.line":256},"message":"Error fetching data for metricset kubernetes.system: error doing HTTP request to fetch 'system' Metricset data: HTTP error 403 in : 403 Forbidden","service.name":"metricbeat","ecs.version":"1.6.0"}
W1208 17:29:07.696492 7 reflector.go:324] pkg/mod/k8s.io/client-go@v0.23.4/tools/cache/reflector.go:167: failed to list *v1.Node: nodes "minikube" is forbidden: User "system:serviceaccount:default:metricbeat" cannot list resource "nodes" in API group "" at the cluster scope
E1208 17:29:07.696530 7 reflector.go:138] pkg/mod/k8s.io/client-go@v0.23.4/tools/cache/reflector.go:167: Failed to watch *v1.Node: failed to list *v1.Node: nodes "minikube" is forbidden: User "system:serviceaccount:default:metricbeat" cannot list resource "nodes" in API group "" at the cluster scope
{"log.level":"error","@timestamp":"2022-12-08T17:29:10.059Z","log.origin":{"file.name":"module/wrapper.go","file.line":256},"message":"Error fetching data for metricset kubernetes.volume: error doing HTTP request to fetch 'volume' Metricset data: HTTP error 403 in : 403 Forbidden","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"error","@timestamp":"2022-12-08T17:29:16.909Z","log.origin":{"file.name":"module/wrapper.go","file.line":256},"message":"Error fetching data for metricset kubernetes.system: error doing HTTP request to fetch 'system' Metricset data: HTTP error 403 in : 403 Forbidden","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"error","@timestamp":"2022-12-08T17:29:20.056Z","log.origin":{"file.name":"module/wrapper.go","file.line":256},"message":"Error fetching data for metricset kubernetes.volume: error doing HTTP request to fetch 'volume' Metricset data: HTTP error 403 in : 403 Forbidden","service.name":"metricbeat","ecs.version":"1.6.0"}
W1208 17:29:22.609017 7 reflector.go:324] pkg/mod/k8s.io/client-go@v0.23.4/tools/cache/reflector.go:167: failed to list *v1.Node: nodes is forbidden: User "system:serviceaccount:default:metricbeat" cannot list resource "nodes" in API group "" at the cluster scope
E1208 17:29:22.609059 7 reflector.go:138] pkg/mod/k8s.io/client-go@v0.23.4/tools/cache/reflector.go:167: Failed to watch *v1.Node: failed to list v1.Node: nodes is forbidden: User "system:serviceaccount:default:metricbeat" cannot list resource "nodes" in API group "" at the cluster scope
{"log.level":"info","@timestamp":"2022-12-08T17:29:23.713Z","log.logger":"monitoring","log.origin":{"file.name":"log/log.go","file.line":185},"message":"Non-zero metrics in the last 30s","service.name":"metricbeat","monitoring":{"metrics":{"beat":{"cgroup":{"memory":{"mem":{"usage":{"bytes":-16142336}}}},"cpu":{"system":{"ticks":15330,"time":{"ms":150}},"total":{"ticks":38400,"time":{"ms":290},"value":38400},"user":{"ticks":23070,"time":{"ms":140}}},"handles":{"limit":{"hard":1048576,"soft":1048576},"open":10},"info":{"ephemeral_id":"9b122d95-00b3-4474-bb31-905ef3a85de3","uptime":{"ms":3875999},"version":"8.4.2"},"memstats":{"gc_next":25431712,"memory_alloc":15002576,"memory_total":2169047624,"rss":196845568},"runtime":{"goroutines":119}},"libbeat":{"config":{"module":{"running":0}},"output":{"events":{"acked":67,"active":0,"batches":18,"total":67},"read":{"bytes":17147},"write":{"bytes":88222}},"pipeline":{"clients":13,"events":{"active":0,"filtered":1,"published":67,"total":68},"queue":{"acked":67}}},"metricbeat":{"kubernetes":{"system":{"events":3,"failures":3},"volume":{"events":3,"failures":3}},"system":{"cpu":{"events":3,"success":3},"filesystem":{"events":1,"success":1},"fsstat":{"events":1,"success":1},"load":{"events":3,"success":3},"memory":{"events":3,"success":3},"network":{"events":42,"success":42},"process":{"events":6,"success":6},"process_summary":{"events":3,"success":3}}},"system":{"load":{"1":0.91,"15":0.92,"5":1.01,"norm":{"1":0.0569,"15":0.0575,"5":0.0631}}}},"ecs.version":"1.6.0"}}
{"log.level":"error","@timestamp":"2022-12-08T17:29:26.912Z","log.origin":{"file.name":"module/wrapper.go","file.line":256},"message":"Error fetching data for metricset kubernetes.system: error doing HTTP request to fetch 'system' Metricset data: HTTP error 403 in : 403 Forbidden","service.name":"metricbeat","ecs.version":"1.6.0"}
{"log.level":"error","@timestamp":"2022-12-08T17:29:30.056Z","log.origin":{"file.name":"module/wrapper.go","file.line":256},"message":"Error fetching data for metricset kubernetes.volume: error doing HTTP request to fetch 'volume' Metricset data: HTTP error 403 in : 403 Forbidden","service.name":"metricbeat","ecs.version":"1.6.0"}
And this is what is happening to me. Can someone please advise about what to do?
Thank you for having the patience to read it all and for your help.
Best regards.
Carlos T.
Hi all.
Thank you all for taking the time to read this.
Although I haven't se any answer I had a notification from Warcolm. Which I appreciate trying to help.
Anyway. As I couldn't make this work I tried a different approch based on the samples files which worked for me and I want to share with you.
I took the 'Metricbeat for Kubernetes Monitoring' configuration sample called that you can find in:
yaml Samples to deploy ECK.
I simply changed it a little bit to have a total of four nodes, two master nodes and two multipurpose, data, ingest and ml nodes.
I also added the part related to filebeat with autodiscovery creating a all-in-one fille which I named eck.yaml with the following content:
kind: Beat
metadata:
spec:
  type: metricbeat
  version: 8.5.2
  elasticsearchRef:
  kibanaRef:
  config:
    metricbeat:
      autodiscover:
        providers:
        - hints:
            default_config: {}
            enabled: "true"
          node: ${NODE_NAME}
          type: kubernetes
      modules:
      - module: system
        period: 10s
        metricsets:
        - cpu
        - load
        - memory
        - network
        - process
        - process_summary
        process:
          include_top_n:
            by_cpu: 5
            by_memory: 5
        processes:
      - module: system
        period: 1m
        metricsets:
        - filesystem
        - fsstat
        processors:
        - drop_event:
            when:
              regexp:
                system:
                  filesystem:
        period: 10s
        node: ${NODE_NAME}
        hosts:
        ssl:
        metricsets:
        - node
        - system
        - pod
        - container
        - volume
    processors:
  daemonSet:
    podTemplate:
      spec:
        containers:
        - args:
          - -e
          - -c
          - /etc/beat.yml
          volumeMounts:
          env:
          - name: NODE_NAME
            valueFrom:
              fieldRef:
        securityContext:
          runAsUser: 0
        volumes:
        - hostPath:
        - hostPath:
        - hostPath:
            path: /proc
kind: ClusterRole
metadata:
rules:
- apiGroups:
  resources:
  - nodes
  - namespaces
  - events
  - pods
  verbs:
  - get
  - list
  - watch
- apiGroups:
  - "extensions"
  resources:
  - replicasets
  verbs:
  - get
  - list
  - watch
- apiGroups:
  - apps
  resources:
  - statefulsets
  - deployments
  - replicasets
  verbs:
  - get
  - list
  - watch
- apiGroups:
  resources:
  - nodes/stats
  verbs:
  - get
- nonResourceURLs:
  - /metrics
  verbs:
  - get
apiVersion: v1
metadata:
  namespace: eck-home
kind: ClusterRoleBinding
metadata:
subjects:
- kind: ServiceAccount
  namespace: eck-home
roleRef:
  kind: ClusterRole
  apiGroup: rbac.authorization.k8s.io
kind: Beat
metadata:
spec:
  type: filebeat
  version: 8.5.2
  elasticsearchRef:
  kibanaRef:
  config:
    filebeat:
      autodiscover:
        providers:
        - type: kubernetes
          node: ${NODE_NAME}
          hints:
            enabled: true
            default_config:
              type: container
              paths:
              - /var/log/containers/*${data.kubernetes.container.id}.log
    processors:
  daemonSet:
    podTemplate:
      spec:
        serviceAccountName: filebeat
        containers:
        - name: filebeat
          securityContext:
            runAsUser: 0
            # If using Red Hat OpenShift uncomment this:
            #privileged: true
          volumeMounts:
          - name: varlogcontainers
            mountPath: /var/log/containers
          - name: varlogpods
            mountPath: /var/log/pods
          - name: varlibdockercontainers
            mountPath: /var/lib/docker/containers
          env:
            - name: NODE_NAME
              valueFrom:
                fieldRef:
        volumes:
          hostPath:
            path: /var/log/containers
        - name: varlogpods
          hostPath:
            path: /var/log/pods
          hostPath:
            path: /var/lib/docker/containers
kind: ClusterRole
metadata:
rules:
- apiGroups: [""] # "" indicates the core API group
  resources:
  - namespaces
  - pods
  - nodes
  verbs:
  - get
  - watch
  - list
apiVersion: v1
metadata:
metadata:
subjects:
  namespace: eck-home
roleRef:
  kind: ClusterRole
kind: Elasticsearch
metadata:
spec:
  version: 8.5.2
  nodeSets:
  - name: master
    count: 2
    config:
      node.roles: master
    podTemplate:
      metadata:
        annotations:
  - name: data
    count: 2
    config:
    podTemplate:
      metadata:
        annotations:
kind: Kibana
metadata:
spec:
  version: 8.5.2
  count: 1
  elasticsearchRef:
I also downloaded the operator
wget https://download.elastic.co/downloads/eck/2.5.0/operator.yaml
And I replaced all 'default' namespaces by 'eck-home' in the operator.yaml file
I created the namespace called 'eck-home'.
I did this because I wanted to deploy ECK in a different namespace than 'default' and check if things could work well.
After that, the steps I run were:
kubectl create -f https://download.elastic.co/downloads/eck/2.5.0/crds.yaml -n eck-home
kubectl apply -f operator.yaml -n eck-home
And
kubectl apply -f eck.yaml -n eck-home
Everything seemed to work well. I've got metricbeat data about the pods, the containers, the K8s nodes, not all dasboards show data but I don't see errors in the documents from Kibana -> Discover.
I also can find document from the filebeat-* dataview that matches with the kubectl logs of my pods. I also deployed the version 8.4.2 and changed afterwards the version to 8.5.2 and the operator did right the update.
So far so good. Maybe in the future I could find strange behaviors and I'll let you know about it, but for now everything is right.
Hope it can help someone. Thank you again.
Regards.
Carlos T.
