I've created ES index using the following command:
curl -X PUT -H 'Content-Type: application/json' -H 'Accept: application/json' -d '{"settings" :{"number_of_shards" : 10, "number_of_replicas" : 0, "analysis":{"analyzer": {"my_analyzer": {"type": "custom", "tokenizer":"whitespace","filter":["lowercase","porter_stem"],"stopwords":[...stopwords here ...]}}}}, "mappings" : {"html" : {"properties" : "head" : { "type" : "text", "analyzer": "my_analyzer" }, "body" : { "type" : "text", "analyzer": "my_analyzer"}}}}}' localhost:9200/docs
I read here that:
Analyzed string fields use positions as the default, and all other fields use docs as the default.
Since my fields are of text
type, are they considered string fields?
My main issue is how to know what does my index contain (docs or positions?) for each field! I used /docs/_settings
command to get the index settings, but didn't get useful answer?
Any hints?
