Query problem with nested fields using DSL with elasticsearch
When I try to query a nested field that exists, I didn't get any result (it
isn't return any error):
            result = es.search(
                      index="mydb",
                      doc_type="collection",
                      body={"query":
                              "term" : {
                                  "foo.bar.field" : value
NOTE: field is inside bar and bar is inside foo:
{ 'topfield' : 23, 'foo' : { 'bar' : { 'field' : 69 }, 'otherfield' : 1}}
If I try the same with a field in the top, it works properly:
            result = es.search(
                      index="mydb",
                      body={"query":
                              "term" : {
                                  "topfield" : value
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/93d419b4-f409-4c57-a2e0-fe528efd3569%40googlegroups.com.
You should use path for your nested fields!!!
please read this article:
Am Mittwoch, 15. Oktober 2014 10:38:24 UTC+2 schrieb José Ramón Palanco:
(it isn't return any error):
            result = es.search(
                      index="mydb",
                      body={"query":
                              "term" : {
            result = es.search(
                      index="mydb",
                      body={"query":
                              "term" : {
                                  "topfield" : value
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/6e045b5f-b709-49a1-9422-5c5bb8ffb8ef%40googlegroups.com.
