Query_string does not work with multiple tokens with the same position
I'm having troubles with query_string query when my analyzer returns multiple tokens for the same position. Here's an output of _analyze for my query:
  "tokens" : [
      "token" : "d",
      "start_offset" : 6,
      "end_offset" : 17,
      "type" : "word",
      "position" : 0
      "token" : "autrefois",
      "start_offset" : 6,
      "end_offset" : 17,
      "type" : "word",
      "position" : 0
      "token" : "dautrefois",
      "start_offset" : 6,
      "end_offset" : 17,
      "type" : "word",
      "position" : 0
But it appears that query_string searches only for token d, whereas I think it should do something like (d OR autrefois OR dautrefois).
Here's the query that I try:
    "query_string": {
      "query": "d'autrfois",
      "fields": ["title"],
      "type": "cross_fields",
      "default_operator": "and",
      "analyzer": "custom_name_analyzer",
Hi @Alex_Shkop
Could you provide the analyzer/mapping and the document?
Hello @RabBit_BR!
Where are using proprietary token filter, so I can't share the analyzer definition, but you have the output from _analyze in my first post. Here's the mapping and the results of the query with explain=true. One is with the original analyzer, another one is with a simple analyzer` provided in a query.
Mapping:
  "crescendo-bo-recording-search" : {
    "aliases" : { },
    "mappings" : {
      "properties" : {
        "title" : {
          "type" : "text",
          "fields" : {
            "keyword" : {
              "type" : "keyword"
          "index_options" : "docs",
          "analyzer" : "custom_name_analyzer"
    "settings" : {
      "index" : {
        "routing" : {
          "allocation" : {
            "include" : {
              "_tier_preference" : "data_content"
        "number_of_shards" : "1",
        "provided_name" : "search",
        "similarity" : {
          "default" : {
            "discount_overlaps" : "true",
            "type" : "BM25"
        "creation_date" : "1667571727010",
        "analysis" : {
          "analyzer" : {
            "custom_name_analyzer" : {
              "filter" : [
                "lowercase",
                "trim",
                "customtokenfilter"
              "type" : "custom",
              "tokenizer" : "whitespace"
        "number_of_replicas" : "5",
        "uuid" : "QSfW_4IxSMW6w8cjD4F8IQ",
        "version" : {
          "created" : "7170399"
Query with custom analyzer:
  "took" : 17,
  "timed_out" : false,
  "_shards" : {
    "total" : 1,
    "successful" : 1,
    "skipped" : 0,
    "failed" : 0
  "hits" : {
    "total" : {
      "value" : 9587,
      "relation" : "eq"
    "max_score" : 6.748128,
    "hits" : [
        "_shard" : "[search][0]",
        "_node" : "A5ZKfzdURX6IKvlBz1Rzzg",
        "_index" : "search",
        "_type" : "_doc",
        "_id" : "CLkKQ4QB1NTMdfY8wCbT",
        "_score" : 6.748128,
        "_source" : {
          "title" : "D"
        "_explanation" : {
          "value" : 6.748128,
          "description" : "sum of:",
          "details" : [
              "value" : 6.748128,
              "description" : "weight(Synonym(title:autrfois title:d title:dautrfois) in 527039) [PerFieldSimilarity], result of:",
              "details" : [
                  "value" : 6.748128,
                  "description" : "score(freq=1.0), computed as boost * idf * tf from:",
                  "details" : [
                      "value" : 2.2,
                      "description" : "boost",
                      "details" : [ ]
                      "value" : 4.741262,
                      "description" : "idf, computed as log(1 + (N - n + 0.5) / (n + 0.5)) from:",
                      "details" : [
                          "value" : 9614,
                          "description" : "n, number of documents containing term",
                          "details" : [ ]
                          "value" : 1101616,
                          "description" : "N, total number of documents with field",
                          "details" : [ ]
                      "value" : 0.646944,
                      "description" : "tf, computed as freq / (freq + k1 * (1 - b + b * dl / avgdl)) from:",
                      "details" : [
                          "value" : 1.0,
                          "description" : "termFreq=1.0",
                          "details" : [ ]
                          "value" : 1.2,
                          "description" : "k1, term saturation parameter",
                          "details" : [ ]
                          "value" : 0.75,
                          "description" : "b, length normalization parameter",
                          "details" : [ ]
                          "value" : 1.0,
                          "description" : "dl, length of field",
                          "details" : [ ]
                          "value" : 3.6625738,
                          "description" : "avgdl, average length of field",
                          "details" : [ ]
              "value" : 0.0,
              "description" : "match on required clause, product of:",
              "details" : [
                  "value" : 0.0,
                  "description" : "# clause",
                  "details" : [ ]
                  "value" : 1.0,
                  "description" : "DocValuesFieldExistsQuery [field=_primary_term]",
                  "details" : [ ]
        "_type" : "_doc",
        "_id" : "LMUdQ4QB1NTMdfY8G9Rs",
        "_source" : {
          "title" : "D"
        "_explanation" : {
          "value" : 6.748128,
          "details" : [
              "value" : 6.748128,
              "description" : "weight(Synonym(title:autrfois title:d title:dautrfois) in 20774) [PerFieldSimilarity], result of:",
              "details" : [
                  "value" : 6.748128,
                  "details" : [
                      "value" : 2.2,
                      "details" : [ ]
                      "value" : 4.741262,
                      "details" : [
                          "value" : 9614,
                          "details" : [ ]
                          "value" : 1101616,
                          "details" : [ ]
                      "value" : 0.646944,
                      "details" : [
                          "value" : 1.0,
                          "details" : [ ]
                          "value" : 1.2,
                          "details" : [ ]
                          "value" : 0.75,
                          "details" : [ ]
                          "value" : 1.0,
                          "details" : [ ]
                          "details" : [ ]
              "value" : 0.0,
              "details" : [
                  "value" : 0.0,
                  "details" : [ ]
                  "value" : 1.0,
                  "details" : [ ]
Query with simple analyzer:
  "took" : 2,
  "_shards" : {
    "total" : 1,
    "successful" : 1,
    "skipped" : 0,
    "failed" : 0
  "hits" : {
    "total" : {
      "value" : 16,
      "relation" : "eq"
    "max_score" : 16.526728,
    "hits" : [
        "_type" : "_doc",
        "_id" : "87YHQ4QB1NTMdfY8Lkd0",
        "_score" : 16.526728,
        "_source" : {
          "title" : "NOEL D AUTREFOIS"
        "_explanation" : {
          "value" : 16.526728,
          "details" : [
              "value" : 5.1201873,
              "description" : "weight(title:d in 1992259) [PerFieldSimilarity], result of:",
              "details" : [
                  "details" : [
                      "value" : 2.2,
                      "details" : [ ]
                      "value" : 4.741262,
                      "details" : [
                          "value" : 9614,
                          "details" : [ ]
                          "value" : 1101616,
                          "details" : [ ]
                      "value" : 0.49087304,
                      "details" : [
                          "value" : 1.0,
                          "description" : "freq, occurrences of term within document",
                          "details" : [ ]
                          "value" : 1.2,
                          "details" : [ ]
                          "value" : 0.75,
                          "details" : [ ]
                          "value" : 3.0,
                          "details" : [ ]
                          "details" : [ ]
              "value" : 11.40654,
              "description" : "weight(title:autrefois in 1992259) [PerFieldSimilarity], result of:",
              "details" : [
                  "value" : 11.40654,
                  "details" : [
                      "value" : 2.2,
                      "details" : [ ]
                      "value" : 10.562386,
                      "details" : [
                          "value" : 28,
                          "details" : [ ]
                          "value" : 1101616,
                          "details" : [ ]
                      "details" : [
                          "value" : 1.0,
                          "details" : [ ]
                          "value" : 1.2,
                          "details" : [ ]
                          "value" : 0.75,
                          "details" : [ ]
                          "value" : 3.0,
                          "details" : [ ]
                          "details" : [ ]
        "_type" : "_doc",
        "_id" : "NLcJQ4QB1NTMdfY8LdgQ",
        "_score" : 14.747822,
        "_source" : {
          "title" : "Valse d'autrefois"
        "_explanation" : {
          "value" : 14.747822,
          "details" : [
              "value" : 4.56906,
              "description" : "weight(title:d in 470) [PerFieldSimilarity], result of:",
              "details" : [
                  "value" : 4.56906,
                  "details" : [
                      "value" : 2.2,
                      "details" : [ ]
                      "value" : 4.741262,
                      "details" : [
                          "value" : 9614,
                          "details" : [ ]
                          "value" : 1101616,
                          "details" : [ ]
                      "value" : 0.43803644,
                      "details" : [
                          "value" : 1.0,
                          "details" : [ ]
                          "value" : 1.2,
                          "details" : [ ]
                          "value" : 0.75,
                          "details" : [ ]
                          "value" : 4.0,
                          "details" : [ ]
                          "details" : [ ]
              "value" : 10.1787615,
              "description" : "weight(title:autrefois in 470) [PerFieldSimilarity], result of:",
              "details" : [
                  "details" : [
                      "value" : 2.2,
                      "details" : [ ]
                      "details" : [
                          "value" : 28,
                          "details" : [ ]
                          "value" : 1101616,
                          "details" : [ ]
                      "details" : [
                          "value" : 1.0,
                          "details" : [ ]
                          "value" : 1.2,
                          "details" : [ ]
                          "value" : 0.75,
                          "details" : [ ]
                          "value" : 4.0,
                          "details" : [ ]
                          "details" : [ ]
Hope this information helps you to understand the issue. In the fist query results, you can see that only d is used to run the query, other tokens are discarded.
