Query_string not returning results for searches less than 3 characters
I'm trying to search for a term such as at&t by only searching for at&, but
it never works. The field is analyzed and boosted on indexing, and I'm
wondering if the only way to get that to work is to create
a separate not_analyzed field?
"fields": [
"name",
"_id"
"query_string": {
"default_field": "name",
"query": "at&"
"size": 15
ok here is my guess.... you analyzer for the field name tokenizes away the
'&' and drops stopwords such that 'at' never makes it to the index so you
get 0 results?
what analyzer are you using for the name field?
simon
but it never works. The field is analyzed and boosted on indexing, and I'm
"fields": [
"name",
"_id"
"query_string": {
"query": "at&"
"size": 15
I'm guessing the default one, that field I didn't do anything special
besides adding a sort field to it. Would it work if I add a new field that
is not analyzed?
get 0 results?
simon
"fields": [
"name",
"_id"
"query_string": {
"query": "at&"
"size": 15
with the default analyzer you will see the behaviour I explained above. If
you use some other analyzer that doesn't drop stopwords you should be fine.
simon
is not analyzed?
the '&' and drops stopwords such that 'at' never makes it to the index so
you get 0 results?
simon
"fields": [
"name",
"_id"
"query_string": {
"query": "at&"
"size": 15
Oddly I tried a few other ones, such as simple or lowercase, or keyword,
really was just throwing things at that point. Making a new psuedo-field
and setting to not_analyzed worked fine, not the best option in my case as
I have to then use a wildcard query to get the behavior I want, but I can
live with it as I get the results fine now. Thanks for the help.
"fields": [
"name",
"_id"
"query_string": {
"query": "at&"
"size": 15
