Questions about using must, should words together and Turkish char problem
Hello
I am using Elasticsearch-oss-7.10.2-1.x86_64. I have 2 questions:
Question 1)
I want to combine this query results:
GET /turkish_example/_search
		"bool": {
		  "should": [
				  "simple_query_string": {
					"fields" : ["adi1","adi2","cevirmen","yazar","sku","listprice"],
					"query" : "MÜBECCEL KIRAY",
								"default_operator": "and"
					"query" : "MÜBECCEL KıRAY",
			  {"term": {"adi1": "Mübeccel B. Kıray"}},
			  {"term": {"adi2": "Mübeccel B. Kıray"}}
  "size": 200,
  "_source": true,
  "fields":["adi1","adi2","sku","cevirmen","basim_tarihi","basim_yeri", "sayfa_sayisi","yazar"]
with:
          "bool": {
      "must_not": [
          "term": {
            "localinventory": "0"
I want to show all results of first query if localinventory is not 0. Is it posible to use should and must words together?
How can I do that?
Question 2)
When I searched for "MÜBECCEL KIRAY" only, I cannot see results properly. I think this problem is related with Turkish chars. Upper I letter should be converted as (lower ı or lower i). I solved this problem by adding some additional queries with "should" word. Is there another suggestion for solving this problem. If I use a single query by replacing I char with ı this time my query doesn't work for "Gurbetteki Kafkasya II". Because II letters shouldn't be replaced like ıı... Using 2 queries solved my problem. Do you have different suggestions?
I tried to create an index by following this document but it didn't help.
I solved this by using following syntax:
GET /kutuphane/_search
   "query":{
      "bool":{
         "must":[
               "simple_query_string":{
                  "fields":[
                     "adi1",
                     "adi2",
                     "cevirmen",
                     "yazar",
                     "sku",
                     "listprice"
                  "query":"(MÜBECCEL KIRAY' | MÜBECCEL KıRAY)",
                  "default_operator":"and"
               "bool":{
                  "should":[
                  "fields":[
                     "adi1",
                     "adi2",
                     "cevirmen",
                     "yazar",
                     "sku",
                     "listprice"
                          {"term": {"adi1": "MÜBECCEL KIRAY"}},
                          {"term": {"adi2": "MÜBECCEL KIRAY"}}
               "bool":{
                  "must_not":[
                        "term":{
                           "localinventory":"0"
   "size":200,
   "_source":true,
   "fields":[
      "adi1",
      "adi2",
      "sku",
      "cevirmen",
      "basim_tarihi",
      "basim_yeri",
      "sayfa_sayisi",
      "yazar"
But I will be happy to hear different suggestions. I am new on ELK queries.
