I have started Elasticsearch on a server which I am trying to connect to my
Rails app. I am able to access ES via curl, however cannot create an index.
'Projects' is the name of my model.
tire.rb
require 'tire'
Tire.configure { url "http://[Server IP]:9200" }
Index command output:
[IMPORT] Deleting index 'projects'
# 2013-07-05 10:52:44:309 [DELETE] ("projects")
curl -X DELETE http://[Server IP]:9200/projects
# 2013-07-05 10:52:44:314 [404]
# {"error":"IndexMissingException[[projects] missing]","status":404}
# 2013-07-05 10:52:44:327 [HEAD] ("projects")
curl -I "http://[Server IP]:9200/projects"
# 2013-07-05 10:52:44:327 [404]
[IMPORT] Creating index 'projects' with mapping:
{"project":{"properties":{}}}
# 2013-07-05 10:52:44:394 [CREATE] ("projects")
curl -X POST http://[Server IP]:9200/projects -d
'{"mappings":{"project":{"properties":{}}},"settings":{}}'
# 2013-07-05 10:52:44:394 [500]
# {"error":"RemoteTransportException[Failed to deserialize exception
response from stream]; nested: TransportSerializationException[Failed to
deserialize exception response from stream]; nested:
StreamCorruptedException[unexpected end of block data]; ","status":500}
[ERROR] There has been an error when creating the index --
Elasticsearch returned:
500 : {"error":"RemoteTransportException[Failed to deserialize
TransportSerializationException[Failed to deserialize exception response
from stream]; nested: StreamCorruptedException[unexpected end of block
Has anyone else run into this error? ES is on a separate server and I am
simply trying to use it for searching in development mode at the moment.
Any help is appreciated.
