Requirement to clear the index data and load fresh data
I have a requirement to clear the existing index data and load the data into the same index whenever we run the logstash config.
How can we achieve this through the config file ?
You are better off deleting the index and recreating it. That will need to be done externally.
Otherwise, create a new index and then use an alias to manage where it points to.
Cant we have the " delete index " (https://www.elastic.co/guide/en/elasticsearch/guide/current/_deleting_an_index.html) Api calls in the logstash config files?
No, sorry.
