Rysiu
May 17, 2020, 3:29pm
1
I have hot phase indexes on certain elasticsearch nodes.
Is it possible to set the index rollover data transmission rate on data flow: hot nodes => warm nodes?
I mean, 'max_concurrent_file_chunks' and/or 'max_bytes_per_sec' as for recovery?
What possibilities do we have to define and manipulate the speed of such data flow?
Yes, those two settings are the ones to use. "Recovery" is the name of the process used to move shards between nodes so these settings apply.
Rysiu
May 18, 2020, 3:49pm
3
Is there a limit to the maximum amount of 'max_concurrent_file_chunks' per cluster?
Is there any option?
Yes, the limit for max_concurrent_file_chunks is 5.
Rysiu
May 18, 2020, 4:03pm
5
But I mean limit not per node, but per cluster.
Is it possible to set this limit per cluster? For example, equal to 8?
No, there's no cluster-wide limit. I'm not sure I understand why you would want such a thing.
