Setting "max_determinized_states" when using _source to filter fields during match_all
I have a long list of fields that I want to include in my results during a match_all query (1600+) This triggers the following error:
* "error": {
  * "root_cause": [
      * "type": "too_complex_to_determinize_exception",
      * "reason": "too_complex_to_determinize_exception: Determinizing automaton with 194115 states and 195742 transitions would result in more than 10000 states."}],
  * "type": "search_phase_execution_exception",
  * "reason": "all shards failed",
  * "phase": "query",
  * "grouped": true,
  * "failed_shards": [
      * "shard": 2,
      * "index": "qa-contracts",
      * "node": "Cm-PbvYVSfypTszrbJIQKQ",
      * "reason": {
        * "reason": "too_complex_to_determinize_exception: Determinizing automaton with 194115 states and 195742 transitions would result in more than 10000 states."}}]},
* "status": 500
My query:
    "match_all": {
  "_source": [
    "BranchCode",
    "BranchInfo.A2DUuid",
    .... 1600 fields here
    "id"
Is it possible to set "max_determinized_states" to more than 10000 while executing this query ?
