Settings for _percolator index
What is the best way to set the settings for the _percolator index? I
create an index benchmark and then let elasticsearch create _percolatorupon registration of the first query. Should I be manually creating the
_percolator index myself so that I can make the settings what I want? Or
is there a way to store off the settings and have elasticsearch read them
automatically when it creates the _percolator index?
_percolator upon registration of the first query. Should I be
manually creating the _percolator index myself so that I can make the
settings what I want? Or is there a way to store off the settings and
have elasticsearch read them automatically when it creates the
_percolator index?
Easiest is probably just to create the _percolator index yourself,
before creating any percolators
clint
What settings are you after?
create an index benchmark and then let elasticsearch create *_percolator
  • upon registration of the first query. Should I be manually creating
    the _percolator index myself so that I can make the settings what I
    want? Or is there a way to store off the settings and have elasticsearch
    read them automatically when it creates the _percolator index?
Whatever ones will get me sub 100 ms percolate responses with >= 100K registered queries.
I think I'm looking for how to distribute percolate requests the way that searches are distributed. But if there's a better approach then I'm looking for that.
Thanks,
Jay
On Thu, Jun 7, 2012 at 4:53 PM, shadow000fire jason.scheller@gmail.com wrote:
What is the best way to set the settings for the _percolator index? I create an index benchmark and then let elasticsearch create _percolator upon registration of the first query. Should I be manually creating the _percolator index myself so that I can make the settings what I want? Or is there a way to store off the settings and have elasticsearch read them automatically when it creates the _percolator index?
You can have several indexes holding parts of the percolated queries, and
execute them in parallel. Its not amazing, and I hope we address this in
the upcoming release.
On Mon, Jun 11, 2012 at 4:24 AM, Jason Scheller jason.scheller@gmail.comwrote:
registered queries.
for that.
Thanks,
Jay
_percolator* upon registration of the first query. Should I be manually
elasticsearch read them automatically when it creates the _percolatorindex?
