[Solved] Filebeat 7.0.1 has no data on [Filebeat System] Syslog dashboard ECS
Hello team,
I have an ELK stack running on 7.0.1 and i have trouble displaying data on the [Filebeat System] Syslog dashboard ECS but i can see logs on the discover panel.
I have configured a linuxclient to send system logs using filebeat to elasticsearch nodes straight. I am using the system module from filebeat.
My linuxclient is running RHEL 7.0 OS and i am trying to display the important logs on kibana.
On my linuxclient:
system.yml
- module: system
  # Syslog
  syslog:
    enabled: true
    # Set custom paths for the log files. If left empty,
    # Filebeat will choose the paths depending on your OS.
    var.paths: ["/var/log/dmesg"]
    # Convert the timestamp to UTC. Requires Elasticsearch >= 6.1.
    var.convert_timezone: true
  # Authorization logs
  auth:
    enabled: true
    var.paths: ["/var/log/secure"]
[root@linuxclient modules.d]#
filebeat.yml
#=========================== Filebeat inputs =============================
filebeat.inputs:
- type: log
  # Change to true to enable this input configuration.
  enabled: true
  # Paths that should be crawled and fetched. Glob based paths.
  paths:
    - /var/log/messages
    - /var/log/cron
    - /var/log/secure
    #- c:\programdata\elasticsearch\logs\*
  # Exclude lines. A list of regular expressions to match. It drops the lines that are
  # matching any regular expression from the list.
  #exclude_lines: ['^DBG']
  exclude_lines: ['.*monitoring.*']
#============================= Filebeat modules ===============================
filebeat.config.modules:
  reload.enabled: true
  #reload.period: 10s
#==================== Elasticsearch template setting ==========================
setup.template.settings:
  index.number_of_shards: 1
  #index.codec: best_compression
  #_source.enabled: false
#============================== Kibana =====================================
# Starting with Beats version 6.0.0, the dashboards are loaded via the Kibana API.
# This requires a Kibana endpoint configuration.
setup.kibana:
  host: "kibana:5601"
#================================ Outputs =====================================
output.elasticsearch:
  hosts: ["esnode1:9200", "esnode2:9200", "esnode3:9200"]
  # Optional protocol and basic auth credentials.
  #protocol: "https"
  #username: "elastic"
  #password: "changeme"
#----------------------------- Logstash output --------------------------------
#output.logstash:
  # The Logstash hosts
  # hosts: ["localhost:5044"]
  # Optional SSL. By default is off.
  # Client Certificate Key
#================================ Processors =====================================
# Configure processors to enhance or manipulate events generated by the beat.
processors:
  - add_host_metadata: ~
  - add_cloud_metadata: ~
#================================ Logging =====================================
#logging.level: debug
#logging.selectors: ["*"]
#============================== Xpack Monitoring
#xpack.monitoring.enabled: false
#xpack.monitoring.elasticsearch:
# Migration
# This allows to enable 6.7 migration aliases
#migration.6_to_7.enabled: true
setup.ilm.enabled: auto
setup.ilm.rollover_alias: "filebeat-linuxclient"
setup.ilm.pattern: "{now/d}-000001"
setup.template.overwrite: true
i have deleted some commented configs due to exceeding word count on this post
Any idea what could be the problem?
Solved this issue.
Apparently, my mistake is that i have loaded "- /var/log/messages" in my prospector settings and i should have place this into the system.yml module.
After that, the dashboard is displaying correctly.
Great! Thanks for posting it here! @TsuWeiQuan
