in order to sort on chinese, i used keworkd-tokenizer and icu_collator
filter, however, i also need to do facet on the same field, the
problem now comes that the facet result is very not friendly as i can
not read it.
besides i aslo want to search on this field, if i passed the result by
icu_collation to the query string, es will complains query parser
failing.
i want to know why localized sort not supported and keep the original
input not encoded by icu_collator?
not read it.
failing.
Maybe ES needs to hide more from you, but at the low level you need 2 fields:
the original text for faceting (keywordtokenizer)
the sort key field for sorting (collated)
the sort key field is really not useful for anything but sorting. its
a binary sort key. this is the same way it works with all databases
too (they just hide the process from you)
logo are trademarks of the
Apache Software Foundation
