Hi all,
Am I able to use both, the output and input Kafka plugins on the same Logstash instance? It seems that the configuration for the consumer continuously loops through all messages in Kafka forever. I'm following a structure similar to this article, the diagram shown below:
Logstash (shipper) | --> Kafka --> | Logstash (indexer)
01.conf | | 02.conf
My 01.conf file is my producer to Kafka, and for testing it looks like this:
stdin { }
kafka {
topic_id => "topicname"
codec => json
It will be light, only sending logs to Kafka.
The configuration to consume Kafka messages (02.conf) looks like this:
kafka {
topics => "topicname"
codec => json
file {
path => "/var/www/test.log"
# elasticsearch { }
For testing, I run the following to load both confs:
bin/logstash -f /etc/logstash/conf.d/
And I get a message that says:
Settings: Default pipeline workers: 1
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/opt/logstash/vendor/bundle/jruby/1.9/gems/logstash-output-kafka-5.0.4/vendor/jar-dependencies/runtime-jars/slf4j-log4j12-1.7.13.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/opt/logstash/vendor/bundle/jruby/1.9/gems/logstash-input-kafka-5.0.4/vendor/jar-dependencies/runtime-jars/slf4j-log4j12-1.7.21.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
SLF4J: Actual binding is of type [org.slf4j.impl.Log4jLoggerFactory]
Pipeline main started
I'm running this on Ubuntu 14.04, Logstash 2.4, the plugin versions of Kafka are both 5.0.4, and Kafka 0.10.0.1.
If I test each config separately, I don't get this problem. It's only when I run both at the same time.
Any help would be greatly appreciated!
Thanks,
Ryan
