Strange errors under very little read/write load when running as cluster but stable on a single node
HI,
I'm experiencing a very strange behaviour with my elasticsearch setup on
AWS.
It is a simple cluster with two nodes on seperate EC2 instances (tried
types: t2.micro, t2.small & m3.medium).
As long as i'm only doing write OR read operations everything is fine and i
get reasonable performance (my testscript causes just a few (~10) writes
per second and/or ~100-200 reads per seconds) - it becomes slow on the
micro instances but that is ok -> setup is just for development & testing.
When i start to do read & write in parallel things become very strange ->
the first 20-50 requests work fine, then it starts to behave strange, more
and more requests begin to hang and my log gets filled with the following
execptions:
org.elasticsearch.transport.ReceiveTimeoutTransportException: [Venus][inet[/
10.1.128.241:9300]][cluster:monitor/nodes/stats[n]] request_id [763838]
timed out after [15000ms]
at org.elasticsearch.transport.TransportService$TimeoutHandler.run(
TransportService.java:366)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.
java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.
java:617)
[2015-03-11 13:55:45,681][DEBUG][action.admin.cluster.node.stats] [Achelous]
failed to execute on node [YsaywggSSv-IPGdIpV9UVw]
10.1.128.241:9300]][cluster:monitor/nodes/stats[n]] request_id [764432]
java:1142)
java:617)
[2015-03-11 13:57:45,682][DEBUG][action.admin.cluster.node.stats] [Achelous]
10.1.128.241:9300]][cluster:monitor/nodes/stats[n]] request_id [765188]
java:1142)
java:617)
[2015-03-11 14:00:15,683][DEBUG][action.admin.cluster.node.stats] [Achelous]
10.1.128.241:9300]][cluster:monitor/nodes/stats[n]] request_id [765704]
timed out after [15001ms]
java:1142)
java:617)
[2015-03-11 14:02:44,584][INFO ][cluster.service ] [Achelous]
removed {[Venus][YsaywggSSv-IPGdIpV9UVw][46cf539b08bf][inet[/10.1.128.241:
9300]],}, reason: zen-disco-node_failed([Venus][YsaywggSSv-IPGdIpV9UVw][
46cf539b08bf][inet[/10.1.128.241:9300]]), reason transport disconnected
[2015-03-11 14:02:44,589][DEBUG][action.search.type ] [Achelous] [
19353] Failed to execute fetch phase
org.elasticsearch.search.SearchContextMissingException: No search context
found for id [19353]
at org.elasticsearch.search.SearchService.findContext(SearchService.java:
508)
at org.elasticsearch.search.SearchService.executeFetchPhase(SearchService.
java:478)
at org.elasticsearch.search.action.SearchServiceTransportAction$17.call(
SearchServiceTransportAction.java:452)
SearchServiceTransportAction.java:449)
at org.elasticsearch.search.action.SearchServiceTransportAction$23.run(
SearchServiceTransportAction.java:559)
java:1142)
java:617)
[2015-03-11 14:02:44,596][DEBUG][action.search.type ] [Achelous] [
19368] Failed to execute fetch phase
found for id [19368]
508)
java:478)
java:1142)
java:617)
[2015-03-11 14:02:44,602][DEBUG][action.search.type ] [Achelous] [
19403] Failed to execute fetch phase
found for id [19403]
508)
java:478)
java:1142)
java:617)
[2015-03-11 14:02:44,603][DEBUG][action.search.type ] [Achelous] [
19404] Failed to execute fetch phase
found for id [19404]
508)
java:478)
java:1142)
java:617)
[2015-03-11 14:02:44,605][WARN ][search.action ] [Achelous]
Failed to send release search context
org.elasticsearch.transport.NodeDisconnectedException: [Venus][inet[/10.1.
128.241:9300]][indices:data/read/search[free_context]] disconnected
[2015-03-11 14:02:44,606][WARN ][search.action ] [Achelous]
[2015-03-11 14:02:44,614][WARN ][search.action ] [Achelous]
[2015-03-11 14:02:44,615][WARN ][search.action ] [Achelous]
[2015-03-11 14:02:44,703][DEBUG][action.admin.indices.stats] [Achelous] [
attendee-dev][3], node[YsaywggSSv-IPGdIpV9UVw], [R], s[STARTED]: failed to
execute [org.elasticsearch.action.admin.indices.stats.
IndicesStatsRequest@2f5eeaae]
128.241:9300]][indices:monitor/stats[s]] disconnected
[2015-03-11 14:02:44,706][WARN ][search.action ] [Achelous]
org.elasticsearch.transport.SendRequestTransportException: [Venus][inet[/
10.1.128.241:9300]][indices:data/read/search[free_context]]
at org.elasticsearch.transport.TransportService.sendRequest(
TransportService.java:213)
TransportService.java:183)
at org.elasticsearch.search.action.SearchServiceTransportAction.
sendFreeContext(SearchServiceTransportAction.java:143)
at org.elasticsearch.action.search.type.
TransportSearchTypeAction$BaseAsyncAction.releaseIrrelevantSearchContexts(
TransportSearchTypeAction.java:341)
TransportSearchQueryThenFetchAction$AsyncAction$2.run(
TransportSearchQueryThenFetchAction.java:158)
java:1142)
java:617)
Caused by: org.elasticsearch.transport.NodeNotConnectedException: [Venus][
inet[/10.1.128.241:9300]] Node not connected
at org.elasticsearch.transport.netty.NettyTransport.nodeChannel(
NettyTransport.java:946)
at org.elasticsearch.transport.netty.NettyTransport.sendRequest(
NettyTransport.java:640)
TransportService.java:199)
... 7 more
[2015-03-11 14:02:44,675][WARN ][search.action ] [Achelous]
java:1142)
java:617)
The really strange thing is that this does not happen when running a single
instance of elasticsearch - it gets slow (as expected) but no errors and no
hangs.
The errors begin to occur at a system load of about 0.6-1.2 -> my single
node test caused loads of 8-10+ and did not cause errors... also using
faster EC2 instacnes m3.medium etc. did not change anything -> so
CPU/Memory can't be the reason - the data set itself is tiny (~5000
documents in 3 indices)
If anyone here has an idea about what may cause this issue please, please
let me know - i already spent a whole day trying to track this issue down
by trying differen ES version config settings and so on.
thank you very much in advance,
kind regards,
Christian
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/55b06673-92c6-4c10-ba36-86699e3249de%40googlegroups.com.
