I am trying to use a term facet with a script_field parameter.
It works well when I use it on a simple field, or when I use it whith
a simple object (like '{"object":{"key":"value"}}'), but it seems to
fail when I try to use it on an object containing an array.
Here is a gist example (with facets output and errors) :
The first query also yielded a strange result, with a missing value.
Does anyone have any insight about what is going on ?
Thanks,
Stéphane
I finally found the answer : you have to use the mvel projection
operator to iterate over the collection :
http://mvel.codehaus.org/MVEL+2.0+Projections+and+Folds
I my example, you can do :
"terms" : {
"script_field" : "(field in _source.array)",
"size" : 10
instead of "script_field" : "_source.array.field"
This does not explains why the "a" element is not taken in account in
the first facets performed on the index, though.
Best,
Stéphane
2012/9/26 Stéphane Raux stephane.raux@gmail.com:
Elastic search terms facets : problems when performing script_field on an object with array · GitHub
Thanks,
Stéphane
