We seem to have stumbled on some issue while running queries against a
local elasticsearch node under a JUnit test.
We've been able to create a small test case which demonstrates this.
The necessary prerequisites for the failure:
- 2 or more shards
 - Any of the DFS search types
 - A terms facet on a field with a "long" type in the mapping
We have tested it with elasticsearch 0.90.x, and different versions of java.
It doesn't always fail, e.g. we have one machine with an old java version
(1.7.0_07) where it works in IntelliJ, but not in maven.
When we run the test against the master-branch the test works, but not on
the 0.90-branch.
public class MyTest {
    private Client client;
    @Before
    public void createNode() throws Exception {
        Settings nodeSettings = ImmutableSettings.settingsBuilder()
                .put("node.local", false)
                .put("path.data", "./target/elasticsearch-test/data")
                .put("path.work", "./target/elasticsearch-test/work")
                .put("path.logs", "./target/elasticsearch-test/logs")
                .put("index.number_of_shards", "2")
                .build();
        Node node = NodeBuilder.nodeBuilder().settings(nodeSettings).node();
        client = node.client();
    @After
    public void cleanup() throws Exception {
        FileSystemUtils.deleteRecursively(new
File("./target/elasticsearch-test/"), true);
    @Test
    public void demonstrateFailure() throws Exception {
        IndexResponse indexResponse = client
                .prepareIndex("test-index", "test-type")
                .setSource("{ \"id\": 123, \"test-value\": 321 }")
                .setRefresh(true)
                .execute()
                .actionGet();
        SearchResponse searchResponse = client
                .prepareSearch("test-index")
                .setQuery(new MatchAllQueryBuilder())
                .addFacet(new
TermsFacetBuilder("test-facet").field("test-value"))
                .setSearchType(SearchType.DFS_QUERY_AND_FETCH)
                .execute()
                .actionGet();
        System.out.println(searchResponse);
        assertEquals(searchResponse.getFailedShards(), 0); // Failing!
Output from a failed run:
  "took" : 68,
  "timed_out" : false,
  "_shards" : {
    "total" : 2,
    "successful" : 0,
    "failed" : 2,
    "failures" : [ {
      "index" : "test-index",
      "shard" : 0,
      "status" : 500,
      "reason" : "ElasticSearchException; nested: AssertionError; "
      "shard" : 1,
      "status" : 500,
  "hits" : {
    "total" : 0,
    "max_score" : 0.0,
    "hits" : [ ]
Regards,
Henrik Nordvik
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/b511afef-4461-477e-a46f-5c3c7f9cdedd%40googlegroups.com.
