Troubleshooting "search load balancer" node connectivity problems
Hi list,
I have 2 VM "search load balancer" nodes and 4 physical master + data nodes.
The 2 search load balancer nodes get disconnected from the physical nodes
very often.
In the process of troubleshooting this I was wondering about following log
entry:
[2014-01-14 09:27:41,528][DEBUG][cluster.service ]
[xxx-xxx-logs-101] set local cluster state to version 512
When is this log generated? Is this automatically scheduled or does this
ONLY occur when the cluster topology changes (something of which I presume
shouldn't happen if all runs stable)
Thanks,
Jelle
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/c337d016-5036-48e9-bb60-afdd7c1f0210%40googlegroups.com.
Never mind,
Root cause was a network issue which got identified.
Setting keepalive in ES kernel params solved the problem.
Cheers,
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/3b4d047b-a350-477a-adb7-7aa8a8b3b610%40googlegroups.com.
