Two systems using the same index
I'm interested in using Elasticsearch for two systems - but only with one Elasticsearch instance.
1. System: Webshop (Magento 2)
2. System: CMS (TYPO3)
In both systems it should be possible so search in its own and the other system.
Therefor I would use one Elasticsearch-Instance/-Index and refer to the system, the specific result refers to.
Is this possible to handle? Have you got any examples/links regarding this requirement?
I wasn't able to find sth. in the documentation.
Thanks for your answer in advance!
Kind regards,
Emil
Yes, this is normal for Elasticsearch to provide.
Just create separate indices in the ciuster.
