How do I write a unit test case using Springboot to check if an index exists in Elasticsearch version 8.7?
dadoonet
(David Pilato)
April 20, 2023, 11:07am
2
This could not be a unit test then. But an integration test.
Yes, I need to write an integration test for springboot+elasticsearch.
dadoonet
(David Pilato)
April 20, 2023, 1:40pm
4
May be this could give you some ideas?
* Licensed to Elasticsearch under one or more contributor
* license agreements. See the NOTICE file distributed with
* this work for additional information regarding copyright
* ownership. Elasticsearch licenses this file to you under
* the Apache License, Version 2.0 (the "License"); you may
* not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing,
* software distributed under the License is distributed on an
* "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY
* KIND, either express or implied. See the License for the
* specific language governing permissions and limitations
* under the License.
package fr.pilato.elasticsearch.injector;
This file has been truncated. show original
