Using dense_vector field in appsearch engine
I want to use fields of type dense_vector in an engine.
It appears it is supported on elastic search but not on app search (Enterprise search).
The documentation at Schema API | Elastic App Search Documentation [7.14] | Elastic lists only text , number , date , geolocation as valid types.
Here is a link to a document that talks about the dense vector support in elastic search.
Is there any way to use dense-vector fields in appsearch engine documents and use cosine similarity scores?
Hi Suresh, thanks for trying App Search.
dense_vector field types are not yet supported in App Search.
Not at this time, but that may change in the future.
