Using elasticsearch as a realtime fire hose
I was wondering whether there were any mechanisms to use ES as a realtime
feed for downstream systems. I have a cluster that gathers observations
from many sensors. I have a need to maintain a list of realtime counters in
REDIS so I want to further process these observation once they hit the
database. Additionally I also want to be able to create event streams for
different type of feeds.
I could do all this outside ES but I was wondering whether there were
mechanisms within ES that will allow me to subscribe to add events for a
particular type or index.
cheers
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/9f5b1d11-0be1-461d-a5bd-dd70f1a0b6c1%40googlegroups.com.
What kind of events do you think of? Single new document indexed? Batch of
docs indexed? Node-wide? Or cluster wide?
You mention Redis, for something like publish/subscribe pattern, you'd have
to use a persistent connection and implement your own ES actions, which is
possible with e.g. HTTP websockets
A sketchy implementation can be found here:
Jörg
cheers
https://groups.google.com/d/msgid/elasticsearch/9f5b1d11-0be1-461d-a5bd-dd70f1a0b6c1%40googlegroups.com?utm_medium=email&utm_source=footer
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/CAKdsXoEkBLfd1pcQ%3D0hf6fstV7oJvO%2BB2GwF%3DdRyNqcN0%3D%2BNzw%40mail.gmail.com.
event on whenever a document is added to an index cluster wide
have to use a persistent connection and implement your own ES actions,
which is possible with e.g. HTTP websockets
GitHub - jprante/elasticsearch-transport-websocket: WebSockets for ElasticSearch
thanks for the reference, I will have a deeper look at it.
Jörg
On Sat, Aug 23, 2014 at 8:09 PM, Jim Alateras <j...@sutoiku.com
cheers
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/7a816e7f-2a58-49ed-8188-08d4483bc2d2%40googlegroups.com.
You might want to look at developing a plugin for this or maybe using an
existing one. This one for example might do partly what you
need: GitHub - derryx/elasticsearch-changes-plugin: An Elasticsearch Plugin that notifies about changes to indices
If you develop your own plugin, you should be able to tap into what is
happening in the cluster at a pretty low level.
Jilles
Jörg
realtime feed for downstream systems. I have a cluster that gathers
observations from many sensors. I have a need to maintain a list of
realtime counters in REDIS so I want to further process these observation
once they hit the database. Additionally I also want to be able to create
event streams for different type of feeds.
cheers
an email to elasticsearc...@googlegroups.com.
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/a3468dc3-2b96-4f00-a921-fba6892b5bba%40googlegroups.com.
