Hi All,
I refer to 'using kibana 4 with shield steps (Using Kibana with Shield | Shield [2.4] | Elastic)' to practice kibana with shield, but got some error log after I restart Kibana
MY ENV (Elasticsearch Cluster: 1 master (140.92.25.126) 1 node (140.92.25.161) ; (Kibana 140.92.25.95)
{"name":"Kibana","hostname":"kibana","pid":53218,"level":60,"err":{"message":"RemoteTransportException[[enode1][inet[/140.92.25.161:9301]][cluster:monitor/health]]; nested: AuthorizationException[action [cluster:monitor/health] is unauthorized for user [franky]]; ","name":"Error","stack":"Error: RemoteTransportException[[enode1][inet[/140.92.25.161:9301]][cluster:monitor/health]]; nested: AuthorizationException[action [cluster:monitor/health] is unauthorized for user [franky]]; \n at respond (/var/www/html/kibana/src/node_modules/elasticsearch/src/lib/transport.js:235:15)\n at checkRespForFailure (/var/www/html/kibana/src/node_modules/elasticsearch/src/lib/transport.js:203:7)\n at HttpConnector. (/var/www/html/kibana/src/node_modules/elasticsearch/src/lib/connectors/http.js:156:7)\n at IncomingMessage.bound (/var/www/html/kibana/src/node_modules/elasticsearch/node_modules/lodash-node/modern/internals/baseBind.js:56:17)\n at IncomingMessage.emit (events.js:117:20)\n at _stream_readable.js:944:16\n at process._tickCallback (node.js:442:13)"},"msg":"","time":"2015-08-05T03:19:19.586Z","v":0}
@ Elasticsearch Master I did
$/usr/share/elasticsearch/bin/shield/esusers useradd franky -r kibana4_monitoring -p password
@ Elasticsearch Master I added following content to roles.yml
kibana4_monitoring:
  cluster:
      - cluster:monitor/nodes/info
      - cluster:monitor/health
  indices:
    'logstash-*':
      - indices:admin/mappings/fields/get
      - indices:admin/validate/query
      - indices:data/read/search
      - indices:data/read/msearch
      - indices:admin/get
    '.kibana':
      - indices:admin/create
      - indices:admin/exists
      - indices:admin/mapping/put
      - indices:admin/refresh
      - indices:data/read/get
      - indices:data/read/mget
      - indices:data/write/delete
      - indices:data/write/index
      - indices:data/write/update
@ Kibana, I modify kibana.yml
kibana_elasticsearch_username: franky
kibana_elasticsearch_password: password
Seems I missing something to configure?
Jason
