Goal: To seamlessly autocomplete addresses while utilizing synonyms.
I have tried to use a standard tokenizer (so that I can use synonyms for
each word) and utilize a match_phrase_prefix but that gives me issues. Two
examples:
- If I type in "500 m" or "500 ma" it will not return the result i'm
looking for. This is because "madison" is far down the expressions list. I
have to go up to around 750 max expressions in order to get this to work
properly - If I type in "500 madison a" it will return no results. This is because
it can't get to "ave" within it's max expressions. I have to go up to
around 7500 max expressions in order for this to work properly.
And that's just not a reasonable solution for autocomplete.
Question: Is there a way to do a filter or preliminary query to get all
results that start with 500. THEN use only the possible matches of that
query for a match_phrase_prefix query? Meaning the demand for max
expressions will be FAR lower.
Maybe there is a different way entirely to do this?
Maybe there is a way to take position into account when calculating the
phrase prefix possibilities?
Maybe each number can be a "type" in my index? Would this mean that the
phrase prefix possibilities would be less?
Synonym Filter:
"synonym": {
"type": "synonym",
"synonyms_path": "analysis/address_syms.txt"
Analysis:
"str_index_analyzer": {
"tokenizer": "standard",
"char_filter": [
"my_filter"
"filter": [
"lowercase",
"synonym"
