What does one index work and other index throw an error using sql queries
I am trying to use sql query on some of the beats indexes and I have observed that some indices are showing up the queries propertly while others are throwing an error:
For example:
curl -XPOST "http://localhost:9200/_xpack/sql?format=txt" -H 'Content-Type: application/json' -d'
  "query" : " DESCRIBE \"metricbeat-6.5.1-*\" "
                                column                                |     type      |    mapping
@timestamp                                                            |TIMESTAMP      |DATE
aerospike                                                             |STRUCT         |OBJECT
aerospike.namespace                                                   |STRUCT         |OBJECT
aerospike.namespace.client                                            |STRUCT         |OBJECT
aerospike.namespace.client.delete                                     |STRUCT         |OBJECT
aerospike.namespace.client.delete.error                               |BIGINT         |LONG
while:
  "query" : " DESCRIBE \"metricbeat-6.6.0-*\" "
is just giving this error:
  "error": {
    "root_cause": [
        "type": "sql_illegal_argument_exception",
        "reason": "Cannot find field container; this is likely a bug"
  "status": 500
Hey there.
We had a somewhat related bug (that issue is here), but I am not sure if it's the same one.
You can check the mappings of your metricbeat-6.6.0-* indices and see if there are any alias type of fields in them. If there are, then there are high chances the issue is the same.
Yeah, there are few alias type of fields in the mapping of that index while the working indices has no alias.
Ok, then yes, very likely this is the issue you are encountering: https://github.com/elastic/elasticsearch/issues/37224. In the issue you can find labels with versions where the issue is fixed.
