What happens if there is an email entered that's longer than 15 characters? In our tests, it appears to stop using edge_ngram, which make sense since it's a "starts with" analyzer but just wanted to be sure on what happens.
Since we don't know how long emails can really be, is it better to use a different analyzer for an email or would it be easier to just bump the "max_gram" to be a higher value?
Mapping field
"email": {
"type": "text",
"index_options": "offsets",
"analyzer": "min_1_max_15_prefix_string_partial_match_index_analyzer",
"search_analyzer": "min_1_string_partial_match_search_analyzer"
Analyzer used upon indexing the field
"min_1_max_15_string_edgeNGram_tokenizer": {
"token_chars": [
"letter",
"digit"
"min_gram": "1",
"type": "edge_ngram",
"max_gram": "15"
The search analyzer used for that field
"min_1_string_partial_match_search_analyzer": {
"filter": [
"standard",
"lowercase"
"char_filter": [
"period_mapping_character_filter"
"type": "custom",
"tokenizer": "standard"
The char_filter for the above search analyzer
"char_filter": {
"period_mapping_character_filter": {
"type": "mapping",
"mappings": ".=>@"
