my cluster has 10 nodes,every node has 24 disk ,
my cluster data path:
path.data: /data1,/data2,/data3,/data4,/data5,/data6,/data7,/data8,/data9,/data10,/data11,/data12,/data13,/data14,/data15,/data16,/data17,/data18,/data19,/data20,/data21,/data22,/data23,/data24
[ela ~]$ for i in `find /data* -name TuiBZL2jRZyiDQZg0e0XuQ`; do du -sh $i; done
12K /data1/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data10/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data11/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data12/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data13/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data14/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data15/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data16/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data17/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data18/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data19/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data2/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data20/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data21/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data22/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data23/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
452G /data24/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data3/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data4/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data5/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data6/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data7/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data8/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
12K /data9/nodes/0/indices/TuiBZL2jRZyiDQZg0e0XuQ
i create a index ,40 shares,I think 4 shares should be saved on each node, and each share will be saved in a different data path, but I see that 4 shares are put in the same data path
This way of data allocation leads to unbalanced use of different data path disks on the nodes
/dev/sdb 1.1T 127G 918G 13% /data1
/dev/sdc 1.1T 77M 1.1T 1% /data2
/dev/sdd 1.1T 152G 892G 15% /data3
/dev/sde 1.1T 157G 887G 16% /data4
/dev/sdf 1.1T 158G 886G 16% /data5
/dev/sdg 1.1T 157G 887G 16% /data6
/dev/sdh 1.1T 235G 809G 23% /data7
/dev/sdi 1.1T 157G 887G 16% /data8
/dev/sdj 1.1T 343G 701G 33% /data9
/dev/sdk 1.1T 154G 890G 15% /data10
/dev/sdl 1.1T 154G 890G 15% /data11
/dev/sdm 1.1T 235G 810G 23% /data12
/dev/sdn 1.1T 154G 890G 15% /data13
/dev/sdo 1.1T 158G 886G 16% /data14
/dev/sdp 1.1T 158G 886G 16% /data15
/dev/sdq 1.1T 157G 887G 16% /data16
/dev/sdr 1.1T 158G 886G 16% /data17
/dev/sds 1.1T 154G 890G 15% /data18
/dev/sdt 1.1T 161G 883G 16% /data19
/dev/sdu 1.1T 412G 632G 40% /data20
/dev/sdv 1.1T 154G 890G 15% /data21
/dev/sdw 1.1T 343G 701G 33% /data22
/dev/sdx 1.1T 77M 1.1T 1% /data23
/dev/sdy 1.1T 639G 405G 62% /data24
Can I improve this situation by modifying the ela configuration
