I want to know the problem with my configuration.
I want to reduce the windows logs saved in Logstash by sending relevant info such as warnings, errors. For now, it's taking a huge amount of data for storing all windows logs. When I am using "type" I am getting error which "could not index events to Elasticsearch". I am attching my json file also.
ThanksProcessing: json.txt...
Please do not post pictures of text, they cannot be searched and are not readable for people who use text-to-speech. Just post the text.
Please edit your post, select the configuration, and click on </> in the toolbar above the edit pane. Then do the same for the data. That will change the appearance from
beats {
host => "192.168.15.151"
port => "5033"
to
beats {
port => "5033"
etc.
I am putting the configuration file for my pipeline here.
beats {
port => "5033"
ssl => true
ssl_certificate => "/etc/logstash/sslCertificate/logstash-remote.crt"
ssl_key => "/etc/logstash/sslCertificate/logstash-remote.key"
type => "winlogevent"
codec => "json"
grok {
match => { "message" => "%{COMBINEDAPACHELOG}"}
#if [type] == "_doc" and [Severity] == "error"{
#mutate {
#add_tag => "error"
Drop informational events
if [type] == "eventlog" and [Severity] == "WARNING" {
drop { }
Drop warning events
if [type] == "eventlog" and [Severity] == "INFO" {
drop { }
#if "error" in [tags]{
hosts => "https://192.168.15.153:9200"
index => "winlogbeat-logstash"
user => "elastic"
password => "el@stic"
cacert => "/etc/logstash/newfile.crt.pem"
ssl => true
ssl_certificate_verification => false
And my json file also
"_index": "winlogbeat-logstash",
"_type": "_doc",
"_id": "4M9xcnsBCY2IxqY0vsaP",
"_version": 1,
"_score": null,
"fields": {
"agent.version.keyword": [
"7.13.2"
"event.category": [
"process"
"host.name.keyword": [
"SSLAB-PSF-CXDC1.SSLAB-PSF.local"
"host.hostname": [
"SSLAB-PSF-CXDC1"
"host.mac": [
"00:50:56:9b:15:1c"
"winlog.process.pid": [
14732
"host.os.version": [
"10.0"
"agent.name": [
"SSLAB-PSF-CXDC1"
"file.directory.keyword": [
"C:\Program Files\Citrix\ConfigSync"
"user.id": [
"S-1-5-20"
"host.os.type": [
"windows"
"agent.id.keyword": [
"5614b39f-b6cb-4ef6-9dd9-bdca3b4cc1cc"
"agent.hostname": [
"SSLAB-PSF-CXDC1"
"file.path.keyword": [
"C:\Program Files\Citrix\ConfigSync\ConfigSync.ps1"
"powershell.sequence": [
1
"tags": [
"beats_input_codec_plain_applied"
"host.architecture": [
"x86_64"
"event.provider": [
"Microsoft-Windows-PowerShell"
"event.code": [
"4104"
"agent.id": [
"winlog.provider_name.keyword": [
"winlog.user.domain.keyword": [
"NT AUTHORITY"
"powershell.total": [
5
"winlog.process.thread.id": [
15672
"winlog.api.keyword": [
"wineventlog"
"tags.keyword": [
"host.ip": [
"192.168.15.107"
"agent.type": [
"winlogbeat"
"event.type.keyword": [
"info"
"host.os.kernel.keyword": [
"10.0.17763.2114 (WinBuild.160101.0800)"
"file.extension.keyword": [
"ps1"
"winlog.api": [
"wineventlog"
"winlog.user.identifier.keyword": [
"S-1-5-20"
"winlog.user.type.keyword": [
"Well Known Group"
"event.provider.keyword": [
"host.id": [
"ff820ffd-67df-4b03-a7b6-4083ffcf5fd1"
"agent.type.keyword": [
"winlogbeat"
"agent.ephemeral_id.keyword": [
"a76c1e2b-30b5-4176-a57e-f604ebde1edd"
"file.directory": [
"agent.name.keyword": [
"SSLAB-PSF-CXDC1"
"file.name": [
"ConfigSync.ps1"
"winlog.user.name": [
"NETWORK SERVICE"
"event.action": [
"Execute a Remote Command"
"@timestamp": [
"2021-08-23T09:56:38.518Z"
"winlog.channel": [
"Microsoft-Windows-PowerShell/Operational"
"host.os.platform": [
"windows"
"winlog.user.name.keyword": [
"NETWORK SERVICE"
"winlog.opcode": [
"On create calls"
"agent.ephemeral_id": [
"winlog.event_id.keyword": [
"4104"
"file.path": [
"host.architecture.keyword": [
"x86_64"
"event.category.keyword": [
"process"
"winlog.provider_name": [
"winlog.provider_guid": [
"{a0c1853b-5c40-4b15-8766-3cf1c58f985a}"
"host.os.build.keyword": [
"17763.2114"
"event.code.keyword": [
"4104"
"winlog.computer_name": [
"user.id.keyword": [
"S-1-5-20"
"agent.hostname.keyword": [
"SSLAB-PSF-CXDC1"
"host.ip.keyword": [
"192.168.15.107"
"ecs.version.keyword": [
"1.9.0"
"winlog.record_id": [
810877
"host.os.name": [
"Windows Server 2019 Standard"
"event.kind.keyword": [
"event"
"log.level": [
"warning"
"event.action.keyword": [
"host.id.keyword": [
"host.name": [
"host.os.version.keyword": [
"10.0"
"event.kind": [
"event"
