I am interested to know, if there is a any work around to index an array of
integer values to a normal integer field, with out modifying the mapping
JSON. Because, I don't want to re-index my huge DB for this field.
What do you mean? You have a field that had single value integer field, and
you want now to index the same field with multiple values? It is supported.
of integer values to a normal integer field, with out modifying the mapping
Won't it affect the older index(existing index), if I try to Index an array
of integers using the JSON format mentioned with field "idarray"?
Or is there something I understood wrong here?
I just wanted to confirm before making changes to my production.
and you want now to index the same field with multiple values? It is
supported.
supported.
logo are trademarks of the
Apache Software Foundation
