mic_2
                (mic-2)
                    June 26, 2012, 12:34am
              1
Excuse my lazy question here, but I was wondering if anyone has experience
with putting thousands of geopoints into a document.
I would love to hear the effect this would have on searching anywhere from
100,000 - 5 million documents (each having 1-100,000 geopoints).
Any additional pointers as to how many geopoints would be within a
reasonable range would be greatly appreciated.
Thanks,
Mic
              I have 70000 documents with approximatly 200 geopoint per documents.
If you want to filter by distance, you should use "plane" distance_type.
Oddly, I have better performance if the cache is enabled on the geodistance
filter (even if searches uses different location)
On Tuesday, June 26, 2012 2:34:27 AM UTC+2, Mic wrote:
Thanks,
Mic
                mic_2
                (mic-2)
                    June 27, 2012,  1:04am
              3
              Sounds like I will be giving this a try. I am going to mock up some test
documents and give this a go.
Thank you very much for sharing your experience with the filter, and
caching, as well. This is great information.
Mic
geodistance filter (even if searches uses different location)
experience with putting thousands of geopoints into a document.
from 100,000 - 5 million documents (each having 1-100,000 geopoints).
Thanks,
Mic
