The prebuilt "cjk" analyzer does indeed use ChineseAnalyzer instead of
CJKAnalyzer.
Instead of using the prebuilt "cjk", try defining a new analyzer
"my_cjk" in your configuration pointing to CjkAnalyzerProvider
instead:
index:
analysis:
analyzer:
my_cjk:
type:
org.elasticsearch.index.analysis.CjkAnalyzerProvider
Then following your example, it appears to be working for me - now
doing the bigram character words that the CJKAnalyzer uses. I'm using
0.15.1.
curl -XPUT 'http://localhost:9200/twitter_jp' -d '{
"index" : {
"numberOfShards" : 1,
"numberOfReplicas" : 1
curl -XPUT 'http://localhost:9200/twitter_jp/_mapping' -d '{
"tweet": {
"properties": {
"user":{"type":"string"},
"postDate":{"type":"string"},
"text": { "type": "string", "index": "analyzed",
"analyzer" : "my_cjk" }
curl -XPUT 'http://localhost:9200/twitter_jp/tweet/1' -d '{
"user": "wolfkden",
"postDate": "Tue Mar 8 22:56:57 PST 2011",
"text": "トヨタ自動車は、ハイブリッド車(HV)「プリウス」のワゴン型試作車「プリウス・スペースコンセプト」を国内で初めて公開
した。"
curl -XGET 'http://localhost:9200/twitter_jp/tweet/_search' -d '{
"query" : {
"match_all" : { }
"facets" : {
"tag" : {
"terms" : {
"field" : "text",
"size" : 30
{"took":182,"timed_out":false,"_shards":{"total":1,"successful":
1,"failed":0},"hits":{"total":1,"max_score":1.0,"hits":
[{"_index":"twitter_jp","_type":"tweet","_id":"1","_score":1.0,
"_source" : {
"user": "wolfkden",
した。"
}}]},"facets":{"tag":{"_type":"terms","missing":0,"terms":[{"term":"開
し","count":1},{"term":"車は","count":1},{"term":"試作","count":1},
{"term":"自動","count":1},{"term":"型試","count":1},{"term":"国内","count":
1},{"term":"動車","count":1},{"term":"初め","count":1},{"term":"内
で","count":1},{"term":"公開","count":1},{"term":"作車","count":1},
{"term":"ース","count":1},{"term":"ン型","count":1},{"term":"ンセ","count":
1},{"term":"ワゴ","count":1},{"term":"リッ","count":1},{"term":"リ
ウ","count":1},{"term":"ヨタ","count":1},{"term":"ペー","count":1},
{"term":"プリ","count":1},{"term":"プト","count":1},{"term":"ブリ","count":
1},{"term":"ハイ","count":1},{"term":"ド車","count":1},{"term":"ト
ヨ","count":1},{"term":"ッド","count":1},{"term":"タ自","count":1},
{"term":"セプ","count":1},{"term":"スペ","count":1},{"term":"スコ","count":
1}]}}}
Hope this helps.
-C
On Mar 11, 3:53 am, Wolf wolfk...@gmail.com wrote:
Thank you Shay for your quick response and personal consideration.
I added more specif analysis mapping for the text field but problems
persist.
I noted your comment on the mapping and followed up with a mapping
declaration after the index declaration:
curl -XPUT 'http://localhost:9200/twitter_jp/_mapping'-d '{
"tweet": {
"properties": {
"analyzer" :
"cjk" }
I also executed the text field mapping with "search_analyzer" : "cjk"
and
with
"index": "not_analyzed", "search_analyzer": "cjk"
switching off the indexing to not_analyzed caused no tokenization to
occur
with the facet response being two terms one for each document. The
interpreter is reading the cjk property since if I make a mispelling I
get a
guice error.
these results used version 0.15.2.
I also compiled a new version of Elasticsearch to use the CJKAnalyzer
for
binding against the cjk parameter in the IndicesAnalysisService class.
This
version produced the same results "I used guice comments to verify
that the
binding code executed".
I am still concerned that I cannot find where the
CJKAnalyzer.tokenStream is
referenced in the code. Possibly the default "standard" tokenizer is
being
used.
Please let me know what else is possibly wrong with my scripts or
other
remedies that I can pursue.
Regards,
Wolf
On Mar 9, 8:00 pm, Wolf wolfk...@gmail.com wrote:
I am using the CJK Analyzer to index Japanese language content into
elasticsearch: However the the input is not tokenized into words but
rather characters. The CJK analyzer does not have this problem when
using a stand alone lucene demonstration program, pp. 147, "Lucene in
Action" second edition, Manning 2010. I also do not have any problems
with Sen in an independent Java demonstration. The following curl
inputs demonstrate my problem.
curl -XPUT 'http://localhost:9200/twitter_jp'-d'{
"index" : {
"numberOfReplicas" : 1,
"analysis" : {
"analyzer" : {
"my_analyzer" : {
"type" : "cjk"
curl -XPUT 'http://localhost:9200/twitter_jp/tweet/1'-d'{
"user": "wolfkden",
した。"
curl -XPUT 'http://localhost:9200/twitter_jp/tweet/2'-d'{
"user": "wolfkden",
"text": "自動車メーカーで生産世界首位。国内販売で「プリウス」が好調も、世界的には大規模リコール問題での信頼回復が急務"
curl -XGET 'http://localhost:9200/twitter_jp/tweet/_search'-d'{
"query" : {
"match_all" : { }
"facets" : {
"tag" : {
"terms" : {
"field" : "text",
"size" : 30
the output provides counts for individual characters rather than
words:
[{"term":"車","count":2},{"term":"自","count":2},{"term":"国","count":2},
{"term":"動","count":2},{"term":"内","count":2},{"term":"ー","count":2},
{"term":"リ","count":2},{"term":"プ","count":2},{"term":"ス","count":2},
{"term":"コ","count":2},{"term":"ウ","count":2},{"term":"は","count":2},
{"term":"の","count":2},{"term":"で","count":2},{"term":"hv","count":1},
{"term":"首","count":1},{"term":"題","count":1},{"term":"頼","count":1},
{"term":"開","count":1},{"term":"販","count":1},{"term":"調","count":1},
{"term":"試","count":1},{"term":"規","count":1},{"term":"的","count":1},
{"term":"界","count":1},{"term":"産","count":1},{"term":"生","count":1},
{"term":"模","count":1},{"term":"急","count":1},{"term":"復","count":1},
{"term":"好","count":1},{"term":"大","count":1},{"term":"売","count":1},
{"term":"型","count":1},{"term":"回","count":1},{"term":"問","count":1},
{"term":"務","count":1},{"term":"初","count":1},{"term":"公","count":1},
{"term":"信","count":1}]}}}
In fact the word プリウス (Prius for toyota Prius) occurs in one of the
documents. I only expect the sen software to pick this prius test out
but the cjk analyzer should tokenize the two character words
correctly.
I checked the elasticsearch code and noted that the cjk analyzer type
is instanced through the CjkAnalysisProvider in the
AnalysisModule.processAnalyzer method. In the IndicesAnalysisService
the cjk setting loads the ChineseAnalyzer rather than the CJKAnalyzer,
I thought this was a problem in the code and made the correction but I
still have the same problem.
All in all though elasticsearch still does not tokenize east asian
words correctly.
Presently my efforts are focusing on the fact that the token stream
from the analyzer is not used and hence the CjK analyzer is not
implemented although the bindings are set.
Could I get some more insight into this to solve my problem.
Regards,
Wolf
