I am trying to create around 150000 docs in elastic but I got the following
error in elastic log file.
what is the reason of this error and how i can solve this error.
I am using elastic 20.5 and jdk"1.6.0_18 .
Not related to the issue: please do not use JDK 1.6.0_18. It is too old
and has bugs. You will run into strange issues with memory. I recommend
the latest Java 7.
Jörg
Am 02.05.13 14:42, schrieb raj:
following error in elastic log file.
the latest Java 7.
Jörg
the latest Java 7.
Jörg
Are you sure that you changed the max open files for the user running
elasticsearch? Are you sure that your values were saved for future
sessions? Both are common gotchas when changing the setting. When you open
a shell as the user running elasticsearch, make sure you have a high ulimit
value:
the latest Java 7.
Jörg
yes i am sure about changed max open files(1024000) for user(root) running
elasticsearch. yes value is saved for future sessions.
any other changed required?
value:
the latest Java 7.
Jörg
"elasticsearch" group.
