Cannot Build Using Gradle; JAVA_HOME Not found
I am trying to build on the custom-realm-example as published on github. However, no matter what I do I am unable to build the project. Here's some details on what's going on:
➜  shield-custom-realm-example git:(master) echo $JAVA_HOME
/Library/Java/JavaVirtualMachines/jdk-10.0.1.jdk/Contents/Home
➜  shield-custom-realm-example git:(master) java -version
'java version "10.0.1" 2018-04-17
Java(TM) SE Runtime Environment 18.3 (build 10.0.1+10)
Java HotSpot(TM) 64-Bit Server VM 18.3 (build 10.0.1+10, mixed mode)
➜  shield-custom-realm-example git:(master) ./gradlew
> Configure project :
Project evaluation failed including an error in afterEvaluate {}. Run with --stacktrace for details of the afterEvaluate {} error.
FAILURE: Build failed with an exception.
* Where:
Build file '~/dev/temp/shield-custom-realm-example/build.gradle' line: 39
* What went wrong:
A problem occurred evaluating root project 'x-pack-custom-realm-extension-example'.
> Failed to apply plugin [id 'elasticsearch.build']
   > JAVA_HOME must be set to build Elasticsearch
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output. Run with --scan to get full insights.
* Get more help at https://help.gradle.org
Deprecated Gradle features were used in this build, making it incompatible with Gradle 5.0.
See https://docs.gradle.org/4.5/userguide/command_line_interface.html#sec:command_line_warnings
BUILD FAILED in 0s
That's why I had this shown in the above logs.
Can you try with Java8 or Java9?
Do you have the gradle daemon enabled? Try running ./gradlew --stop and then running your build again. Also, is your JAVA_HOME variable exported?
@dadoonet I could not find a site that would allow me download java9 JDK, seems like oracle has removed it? I cant use JDK8 to build elasticsearch 6 plugins
@rjernst Please look at the first two lines in the logs I posted above. I have echoed the $JAVA_HOME variable, is there more than that to it?
I'm using sdkman to switch from one jvm to another. Give it a try may be?
@rjernst asked if the JAVA_HOME is exported. That is different to simply setting the variable.
If you want the variable to be available to a child process (which you do) then you need to
export JAVA_HOME
before build export JAVA_HOME with you correct java
