Hi guys,
I need an urgent help to setup Elasticsearch cluster on Amazon EC2
instances as I have to launch an application within a week. I'm trying this
for the last three days without success. I tried to follow many
instructions, created instances all over again and still nothing. I can
telnet instances on 9300. I added security group ES2 having a port range
0-65535 and also individual instances by private IP addresses with range
9200-9400. Nodes can't discover each other,and it seems that both nodes are
created on their own regardless the fact that cluster node info indicates
that good elasticsearch.yml is used. For example, cluster name is the one I
added in elasticsearch.yml, but node name is generic one.
I hope somebody will have some idea if I missed something here.
Here are other details:
My IAM policy is:
"Version": "2012-10-17",
"Statement": [
"Sid": "Stmt1412960658000",
"Effect": "Allow",
"Action": [
"ec2:DescribeInstances"
"Resource": [
Cluster configurations are as follows:
######################Master node configuration
cluster.name: elasticsearch
node.name: "Slave_node"
node.master: false
discovery.ec2.availability_zones: us-east-1
discovery.ec2.ping_timeout: 30s
cloud.aws.protocol:http
plugin.mandatory:cloud-aws
discovery.zen.ping.multicast.enabled:false
discovery.ec2.groups:ES2
#discovery.ec2.tag.type:ElasticsearchCluster
network.publish_host:255.255.255.255
discovery.type:ec2
cloud.aws.access_key:
cloud.aws.secret_key:
discovery.zen.ping.unicast.hosts:["10.185.210.54[9300-9400]",
"10.101.176.236[9300-9400]"]
cloud.node.auto_attributes:true
###############################Slave node configuration
node.master: false
discovery.type:ec2
##############TRACE LOG FROM SLAVE NODE
[2014-10-10 17:21:30,554][INFO ][node ] [Gabriel the Air
-Walker] started
[2014-10-10
17:21:30,554][DEBUG][cluster.service ] [Gabriel the
Air-Walker] processing [updating local node id]: done applying updated
cluster_state (version: 3)
[2014-10-10 17:21:40,504][DEBUG][cluster.service ] [Gabriel the Air
-Walker] processing [routing-table-updater]: execute
[2014-10-10
17:21:40,505][DEBUG][cluster.service ] [Gabriel the
Air-Walker] processing [routing-table-updater]: no change in
cluster_state
[2014-10-10
17:21:44,122][DEBUG][plugins ] [Gabriel the Air-Walker]
[/usr/share/elasticsearch/plugins/cloud-aws/_site] directory does not
exist.
[2014-10-10 17:21:44,123][DEBUG][plugins ]
[/usr/share/elasticsearch/plugins/mapper-attachments/_site] directory
does not exist.
[2014-10-10 17:22:04,288][INFO ][node ] [Gabriel the Air
-Walker] stopping ...
[2014-10-10 17:22:04,314][INFO ][node ] [Gabriel the Air
-Walker] stopped
-Walker] closing ...
[2014-10-10 17:22:04,320][INFO ][node ] [Gabriel the Air
-Walker] closed
[2014-10-10
17:22:06,170][INFO ][node ] [Giant-Man]
version[1.1.0], pid[3523], build[2181e11/2014-03-25T15:59:51Z]
[2014-10-10 17:22:06,171][INFO ][node ] [Giant-Man]
initializing ...
[2014-10-10
17:22:06,171][DEBUG][node ] [Giant-Man] using home
[/usr/share/elasticsearch], config [/etc/elasticsearch], data
[[/var/lib/elasticsearch]], logs [/var/log/elasticsearch], work
[/tmp/elasticsearch], plugins [/usr/share/elasticsearch/plugins]
[2014-10-10
17:22:06,212][DEBUG][plugins ] [Giant-Man]
exist.
[2014-10-10 17:22:06,231][DEBUG][plugins ]
[Giant-Man] [/usr/share/elasticsearch/plugins/mapper-attachments/_site]
directory does not exist.
[2014-10-10
17:22:06,251][DEBUG][plugins ] [Giant-Man]
exist.
[2014-10-10 17:22:06,251][DEBUG][plugins ]
[2014-10-10 17:22:06,251][INFO
][plugins ] [Giant-Man] loaded [mapper-attachments,
cloud-aws], sites [head, bigdesk]
[2014-10-10 17:22:06,268][DEBUG][common.compress.lzf ] using [
UnsafeChunkDecoder] decoder
[2014-10-10
17:22:06,280][DEBUG][env ] [Giant-Man] using node
location [[/var/lib/elasticsearch/elasticsearch/nodes/0]], local_node_id
[0]
[2014-10-10 17:22:07,992][DEBUG][threadpool ]
[Giant-Man] creating thread_pool [generic], type [cached], keep_alive
[30s]
[2014-10-10 17:22:08,001][DEBUG][threadpool ]
[Giant-Man] creating thread_pool [index], type [fixed], size [2],
queue_size [200]
[2014-10-10
17:22:08,005][DEBUG][threadpool ] [Giant-Man] creating
thread_pool [bulk], type [fixed], size [2], queue_size [50]
[2014-10-10
thread_pool [get], type [fixed], size [2], queue_size [1k]
[2014-10-10
thread_pool [search], type [fixed], size [6], queue_size [1k]
[2014-10-10
thread_pool [suggest], type [fixed], size [2], queue_size [1k]
[2014-10-10
17:22:08,006][DEBUG][threadpool ] [Giant-Man] creating
thread_pool [percolate], type [fixed], size [2], queue_size [1k]
[2014-10-10
thread_pool [management], type [scaling], min [1], size [5], keep_alive
[5m]
[2014-10-10 17:22:08,007][DEBUG][threadpool ]
[Giant-Man] creating thread_pool [flush], type [scaling], min [1], size
[1], keep_alive [5m]
[2014-10-10
17:22:08,007][DEBUG][threadpool ] [Giant-Man] creating
thread_pool [merge], type [scaling], min [1], size [1], keep_alive [5m]
[2014-10-10
thread_pool [refresh], type [scaling], min [1], size [1], keep_alive
[5m]
[Giant-Man] creating thread_pool [warmer], type [scaling], min [1], size
[2014-10-10
thread_pool [snapshot], type [scaling], min [1], size [1], keep_alive
[5m]
[Giant-Man] creating thread_pool [optimize], type [fixed], size [1],
queue_size [null]
[2014-10-10
17:22:08,044][DEBUG][transport.netty ] [Giant-Man] using
worker_count[4], port[9300-9400], bind_host[null], publish_host[null],
compress[false], connect_timeout[30s], connections_per_node[2/3/6/1/1],
receive_predictor[512kb->512kb]
[2014-10-10
17:22:08,054][DEBUG][discovery.zen.ping.multicast] [Giant-Man] using
group [224.2.2.4], with port [54328], ttl [3], and address [null]
[2014-10-10 17:22:08,059][DEBUG][discovery.zen.ping.unicast] [Giant-Man]
using initial hosts [], with concurrent_connects [10]
[2014-10-10
17:22:08,060][DEBUG][discovery.zen ] [Giant-Man] using
ping.timeout [3s], master_election.filter_client [true],
master_election.filter_data [false]
[2014-10-10 17:22:08,061][DEBUG][discovery.zen.elect ] [Giant-Man]
using minimum_master_nodes [-1]
[2014-10-10
17:22:08,062][DEBUG][discovery.zen.fd ] [Giant-Man] [master]
uses ping_interval [1s], ping_timeout [30s], ping_retries [3]
[2014-10-10
17:22:08,076][DEBUG][discovery.zen.fd ] [Giant-Man] [node ]
[2014-10-10
17:22:08,109][DEBUG][monitor.jvm ] [Giant-Man] enabled
[true], last_gc_enabled [false], interval [1s], gc_threshold
[{old=GcThreshold{name='old', warnThreshold=10000, infoThreshold=5000,
debugThreshold=2000}, default=GcThreshold{name='default',
warnThreshold=10000, infoThreshold=5000, debugThreshold=2000},
young=GcThreshold{name='young', warnThreshold=1000, infoThreshold=700,
debugThreshold=400}}]
[2014-10-10
17:22:08,619][DEBUG][monitor.os ] [Giant-Man] Using probe
[org.elasticsearch.monitor.os.SigarOsProbe@4f7f3c0a] with
refresh_interval [1s]
[2014-10-10
17:22:08,626][DEBUG][monitor.process ] [Giant-Man] Using probe
[org.elasticsearch.monitor.process.SigarProcessProbe@4e4d2a69] with
[2014-10-10 17:22:08,632][DEBUG][monitor.jvm ] [Giant-Man]
Using refresh_interval [1s]
[2014-10-10
17:22:08,632][DEBUG][monitor.network ] [Giant-Man] Using probe
[org.elasticsearch.monitor.network.SigarNetworkProbe@260e8c6f] with
refresh_interval [5s]
[2014-10-10 17:22:08,638][DEBUG][monitor.network ] [Giant-Man]
net_info
host [ip-10-185-210-54]
eth0 display_name [eth0]
address [/fe80:0:0:0:2000:bff:fe35:17ee%2] [/10.185.210.54]
mtu [1500] multicast [true] ptp [false] loopback [false] up [true]
virtual [false]
lo display_name [lo]
address [/0:0:0:0:0:0:0:1%1] [/127.0.0.1]
mtu [65536] multicast [false] ptp [false] loopback [true] up [true]
virtual [false]
[2014-10-10
17:22:08,642][DEBUG][monitor.fs ] [Giant-Man] Using probe
[org.elasticsearch.monitor.fs.SigarFsProbe@1184fef1] with
[2014-10-10
17:22:08,976][DEBUG][indices.store ] [Giant-Man] using
indices.store.throttle.type [MERGE], with
index.store.throttle.max_bytes_per_sec [20mb]
[2014-10-10 17:22:08,996][DEBUG][script ] [Giant-Man]
using script cache with max_size [500], expire [null]
[2014-10-10
17:22:09,002][DEBUG][cluster.routing.allocation.decider] [Giant-Man]
using node_concurrent_recoveries [2], node_initial_primaries_recoveries
[4]
[2014-10-10
17:22:09,003][DEBUG][cluster.routing.allocation.decider] [Giant-Man]
using [cluster.routing.allocation.allow_rebalance] with
[indices_all_active]
[2014-10-10 17:22:09,003][DEBUG][cluster.routing.allocation.decider]
[Giant-Man] using [cluster_concurrent_rebalance] with [2]
[2014-10-10 17:22:09,008][DEBUG][gateway.local ] [Giant-Man]
using initial_shards [quorum], list_timeout [30s]
[2014-10-10
17:22:09,030][DEBUG][indices.recovery ] [Giant-Man] using
max_bytes_per_sec[20mb], concurrent_streams [3], file_chunk_size
[512kb], translog_size [512kb], translog_ops [1000], and compress [true]
[2014-10-10
17:22:09,197][DEBUG][http.netty ] [Giant-Man] using
max_chunk_size[8kb], max_header_size[8kb], max_initial_line_length[4kb],
max_content_length[100mb], receive_predictor[512kb->512kb]
[2014-10-10
17:22:09,206][DEBUG][indices.memory ] [Giant-Man] using
index_buffer_size [100.7mb], with min_shard_index_buffer_size [4mb],
max_shard_index_buffer_size [512mb], shard_inactive_time [30m]
[2014-10-10
17:22:09,208][DEBUG][indices.cache.filter ] [Giant-Man] using
[node] weighted filter cache with size [20%], actual_size [201.4mb],
expire [null], clean_interval [1m]
[2014-10-10 17:22:09,209][DEBUG][indices.fielddata.cache ] [Giant-Man]
using size [-1] [-1b], expire [null]
[2014-10-10
17:22:09,232][DEBUG][gateway.local.state.meta ] [Giant-Man] using
gateway.local.auto_import_dangled [YES], with
gateway.local.dangling_timeout [2h]
[2014-10-10 17:22:09,245][DEBUG][gateway.local.state.meta ] [Giant-Man]
took 13ms to load state
[2014-10-10 17:22:09,246][DEBUG][gateway.local.state.shards] [Giant-Man]
took 0s to load started shards state
[2014-10-10
17:22:09,249][DEBUG][bulk.udp ] [Giant-Man] using
enabled [false], host [null], port [9700-9800], bulk_actions [1000],
bulk_size [5mb], flush_interval [5s], concurrent_requests [4]
[2014-10-10
17:22:09,253][DEBUG][cluster.routing.allocation.decider] [Giant-Man]
[4]
[2014-10-10
17:22:09,255][DEBUG][cluster.routing.allocation.decider] [Giant-Man]
[2014-10-10 17:22:09,256][DEBUG][cluster.routing.allocation.decider]
[2014-10-10
17:22:09,257][DEBUG][cluster.routing.allocation.decider] [Giant-Man]
[4]
[2014-10-10
[2014-10-10 17:22:09,258][DEBUG][cluster.routing.allocation.decider]
[2014-10-10 17:22:09,270][INFO ][node ] [Giant-Man]
initialized
[2014-10-10 17:22:09,271][INFO ][node ] [Giant-Man]
starting ...
[2014-10-10 17:22:09,290][DEBUG][netty.channel.socket.nio.SelectorUtil]
Using select timeout of 500
Epoll-bug workaround enabled = false
[2014-10-10 17:22:09,429][DEBUG][transport.netty ] [Giant-Man]
Bound to address [/0:0:0:0:0:0:0:0:9300]
[2014-10-10
17:22:09,432][INFO ][transport ] [Giant-Man]
bound_address {inet[/0:0:0:0:0:0:0:0:9300]}, publish_address
{inet[/10.185.210.54:9300]}
[2014-10-10
17:22:09,454][TRACE][discovery ] [Giant-Man] waiting for
30s for the initial state to be set by the discovery
[2014-10-10 17:22:09,460][TRACE][discovery.zen.ping.multicast] [Giant-Man]
[1] sending ping request
[2014-10-10 17:22:10,961][TRACE][discovery.zen.ping.multicast] [Giant-Man]
[2014-10-10 17:22:12,464][TRACE][discovery.zen ] [Giant-Man]
full ping responses: {none}
[2014-10-10
17:22:12,464][DEBUG][discovery.zen ] [Giant-Man] filtered
ping responses: (filter_client[true], filter_data[false]) {none}
[2014-10-10 17:22:12,468][DEBUG][cluster.service ] [Giant-Man]
processing [zen-disco-join (elected_as_master)]: execute
[2014-10-10
17:22:12,469][DEBUG][cluster.service ] [Giant-Man] cluster
state updated, version [1], source [zen-disco-join (elected_as_master)]
[2014-10-10
17:22:12,470][INFO ][cluster.service ] [Giant-Man] new_master
[Giant-Man][jBBOiyjGS_aGNhomzdcvoQ][ip-10-185-210-54][inet[/10.185.210.54:9300]],
reason: zen-disco-join (elected_as_master)
[2014-10-10
17:22:12,503][DEBUG][transport.netty ] [Giant-Man] connected to
node
[[Giant-Man][jBBOiyjGS_aGNhomzdcvoQ][ip-10-185-210-54][inet[/10.185.210.54:9300]]]
[2014-10-10 17:22:12,503][DEBUG][cluster.service ] [Giant-Man]
publishing cluster state version 1
[2014-10-10 17:22:12,504][DEBUG][cluster.service ] [Giant-Man] set
local cluster state to version 1
[2014-10-10 17:22:12,506][DEBUG][river.cluster ] [Giant-Man]
processing [reroute_rivers_node_changed]: execute
[2014-10-10
17:22:12,506][DEBUG][river.cluster ] [Giant-Man] processing
[reroute_rivers_node_changed]: no change in cluster_state
[2014-10-10 17:22:12,506][TRACE][discovery ] [Giant-Man]
initial state set from discovery
[2014-10-10
17:22:12,506][DEBUG][cluster.service ] [Giant-Man] processing
[zen-disco-join (elected_as_master)]: done applying updated
cluster_state (version: 1)
[2014-10-10 17:22:12,507][INFO ][discovery ] [Giant-Man]
elasticsearch/jBBOiyjGS_aGNhomzdcvoQ
[2014-10-10 17:22:12,520][DEBUG][cluster.service ] [Giant-Man]
processing [local-gateway-elected-state]: execute
[2014-10-10
17:22:12,531][DEBUG][cluster.service ] [Giant-Man] cluster
state updated, version [2], source [local-gateway-elected-state]
[2014-10-10 17:22:12,531][DEBUG][cluster.service ] [Giant-Man]
publishing cluster state version 2
[2014-10-10 17:22:12,532][DEBUG][cluster.service ] [Giant-Man] set
local cluster state to version 2
[2014-10-10
17:22:12,535][INFO ][http ] [Giant-Man]
bound_address {inet[/0:0:0:0:0:0:0:0:9200]}, publish_address
{inet[/10.185.210.54:9200]}
[2014-10-10 17:22:12,537][DEBUG][river.cluster ] [Giant-Man]
[2014-10-10
17:22:12,537][DEBUG][river.cluster ] [Giant-Man] processing
[2014-10-10 17:22:12,546][INFO ][gateway ] [Giant-Man]
recovered [0] indices into cluster_state
[2014-10-10
17:22:12,546][DEBUG][cluster.service ] [Giant-Man] processing
[local-gateway-elected-state]: done applying updated cluster_state
(version: 2)
[2014-10-10 17:22:12,546][DEBUG][cluster.service ] [Giant-Man]
processing [updating local node id]: execute
[2014-10-10
17:22:12,546][DEBUG][cluster.service ] [Giant-Man] cluster
state updated, version [3], source [updating local node id]
[2014-10-10 17:22:12,547][DEBUG][cluster.service ] [Giant-Man]
publishing cluster state version 3
[2014-10-10 17:22:12,547][DEBUG][cluster.service ] [Giant-Man] set
local cluster state to version 3
[2014-10-10 17:22:12,547][DEBUG][river.cluster ] [Giant-Man]
[2014-10-10
17:22:12,547][DEBUG][river.cluster ] [Giant-Man] processing
[2014-10-10 17:22:12,547][INFO ][node ] [Giant-Man]
started
[2014-10-10
17:22:12,548][DEBUG][cluster.service ] [Giant-Man] processing
[updating local node id]: done applying updated cluster_state (version:
3)
[2014-10-10 17:22:22,505][DEBUG][cluster.service ] [Giant-Man]
[2014-10-10
17:22:22,505][DEBUG][cluster.service ] [Giant-Man] processing
[routing-table-updater]: no change in cluster_state
#######################################Cluster node info
name: Hammer and Anvil
transport_address: inet[/10.101.176.236:9300]
host: ip-10-101-176-236
ip: 10.101.176.236
version: 1.1.0
build: 2181e11
http_address: inet[/10.101.176.236:9200]
settings: {
path: {
data: /var/lib/elasticsearch
work: /tmp/elasticsearch
home: /usr/share/elasticsearch
conf: /etc/elasticsearch
logs: /var/log/elasticsearch
pidfile: /var/run/elasticsearch.pid
cluster: {
config: /etc/elasticsearch/elasticsearch.yml
os: {
refresh_interval: 1000
available_processors: 2
cpu: {
vendor: Intel
model: Xeon
mhz: 2500
total_cores: 2
total_sockets: 2
cores_per_socket: 32
cache_size_in_bytes: 25600
mem: {
total_in_bytes: 7878475776
swap: {
total_in_bytes: 0
process: {
max_file_descriptors: 65535
mlockall: false
jvm: {
pid: 3109
version: 1.7.0_55
vm_name: OpenJDK 64-Bit Server VM
vm_version: 24.51-b03
vm_vendor: Oracle Corporation
start_time: 1412961257768
mem: {
heap_init_in_bytes: 268435456
heap_max_in_bytes: 1056309248
non_heap_init_in_bytes: 24313856
non_heap_max_in_bytes: 224395264
direct_max_in_bytes: 1056309248
gc_collectors: [
ParNew
ConcurrentMarkSweep
memory_pools: [
Code Cache
Par Eden Space
Par Survivor Space
CMS Old Gen
CMS Perm Gen
thread_pool: {
generic: {
type: cached
keep_alive: 30s
index: {
type: fixed
min: 2
max: 2
queue_size: 200
get: {
type: fixed
min: 2
max: 2
queue_size: 1k
snapshot: {
type: scaling
min: 1
max: 1
keep_alive: 5m
merge: {
type: scaling
min: 1
max: 1
keep_alive: 5m
suggest: {
type: fixed
min: 2
max: 2
queue_size: 1k
bulk: {
type: fixed
min: 2
max: 2
queue_size: 50
optimize: {
type: fixed
min: 1
max: 1
warmer: {
type: scaling
min: 1
max: 1
keep_alive: 5m
flush: {
type: scaling
min: 1
max: 1
keep_alive: 5m
search: {
type: fixed
min: 6
max: 6
queue_size: 1k
percolate: {
type: fixed
min: 2
max: 2
queue_size: 1k
management: {
type: scaling
min: 1
max: 5
keep_alive: 5m
refresh: {
type: scaling
min: 1
max: 1
keep_alive: 5m
network: {
refresh_interval: 5000
primary_interface: {
address: 10.101.176.236
mac_address: 22:00:0B:36:04:47
transport: {
bound_address: inet[/0:0:0:0:0:0:0:0:9300]
publish_address: inet[/10.101.176.236:9300]
http: {
bound_address: inet[/0:0:0:0:0:0:0:0:9200]
publish_address: inet[/10.101.176.236:9200]
max_content_length_in_bytes: 104857600
plugins: [
version: 2.1.0
description: Cloud AWS Plugin
jvm: true
site: false
version: 2.0.0
description: Adds the attachment type allowing to parse
difference attachment formats
jvm: true
site: false
version: NA
description: No description found.
url: /_plugin/head/
jvm: false
site: true
version: NA
url: /_plugin/bigdesk/
jvm: false
site: true
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/a295e5db-186d-4eb8-a42b-c48caf6c4770%40googlegroups.com.
