I have a strange problem, in fact I have configured shield with Kibana and after creating many users I can not connect with any of these users.
Thank you for your help.
Max
Hi Max,
Do the users work when accessing elasticsearch directly?
Yes it works..
Thanks for your reply
This is odd. What versions of elasticsearch, kibana and shield are you using? Do you see any messages in your kibana log file?
My versions are:
kibana 4.5
shield 2.3.1
elasticseach 2.3.1
I see no logs in kibana...
Do you have cors enabled in your elasticsearch.yml file? This may be the issue https://github.com/elastic/kibana/issues/6719#issuecomment-204448145
I have nothing in my elasticsearch.yml file.
No line corresponds to it.
This is a strange log from elasticsearch:
[2016-04-19 14:58:17,275][WARN ][shield.transport.netty ] [Ncer14eld1A] Caught exception while handling client http traffic, closing connection [id: 0xe1a7ccb2, /x.x.x.xx:46554 => /x.x.x.xx:9200]
java.lang.IllegalArgumentException: empty text
at org.jboss.netty.handler.codec.http.HttpVersion.(HttpVersion.java:89)
at org.jboss.netty.handler.codec.http.HttpVersion.valueOf(HttpVersion.java:62)
at org.jboss.netty.handler.codec.http.HttpRequestDecoder.createMessage(HttpRequestDecoder.java:75)
at org.jboss.netty.handler.codec.http.HttpMessageDecoder.decode(HttpMessageDecoder.java:191)
at org.jboss.netty.handler.codec.http.HttpMessageDecoder.decode(HttpMessageDecoder.java:102)
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:500)
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435)
at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70)
at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564)
at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791)
at org.elasticsearch.common.netty.OpenChannelsHandler.handleUpstream(OpenChannelsHandler.java:75)
at org.jboss.netty.handler.ipfilter.IpFilteringHandlerImpl.handleUpstream(IpFilteringHandlerImpl.java:154)
at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559)
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268)
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255)
at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88)
at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108)
at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:337)
at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89)
at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178)
at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108)
at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
Can you share your kibana configuration? And to confirm, you have made no changes to the elasticsearch configuration?
you are using a https URL to connect to elasticsearch in your kibana.yml file but do not have SSL enabled on elasticsearch. Try changing https to http
it works !
thanks so much
