Connection refused to connect elastic through ip with same machine
Hi am new to elastic search,
i hitting loclhost:9200 it's working fine but when i hit IP:9200 that's not connected with same machine elastic installed? what should i do?
Change network.host in your configuration file. More on important settings in the documentation.
i changed sir but it's not working
i had elastic 6.6.1 while i running through command prompt its automatically stop the service
Error resolved mistake of not remove the # symbol at the network.host line in yml file
