Correct Way to Execute Not Exists and Not Empty Query for Not_Analyzed Fields in Nested Document
I have a "not_analyzed" field as part of a nested document in my schema. A sample document is given below
"_source": {
    "identifier": 123,
    "nested_doc_name_xyz":[
        "not_analyzed_field_name_xyz": [
           "ABCD",
           "1234",
To search for documents where not_analyzed_field_name_xyz does not exist and is not empty, the following is the query chunk I am using.
  "bool": {
    "filter": {
      "bool": {
        "must_not": {
          "nested": {
            "path": "nested_doc_name_xyz",
              "bool": {
                "must": {
                  "exists": {
                    "field": "nested_doc_name_xyz.not_analyzed_field_name_xyz"
                "must_not": {
                  "term": {
                    "nested_doc_name_xyz.not_analyzed_field_name_xyz": ""
Since the sample document I provided earlier, has an empty string as part of the whole value,
           "ABCD",
           "1234",
the search query given above is not returning the document with identifier 123.
Ideally, I want to filter out documents which
  1. do not have "nested_doc_name_xyz.not_analyzed_field_name_xyz" this field
    and
  2. those which have value for this field as ("nested_doc_name_xyz.not_analyzed_field_name_xyz": [""] or "nested_doc_name_xyz.not_analyzed_field_name_xyz":"")
Please let me know if you need any more details.
Can you post the index mappings for your sample document?
I believe the query needs to look like:
  "size": 0,
    "bool": {
      "must": [
          # nested query satisfying condition 1
          "bool": {
            "should": [
                # nested condition 2 checking for blank value
                # nested condition 2 checking for blank array
Having the index mappings might be helpful.
Thanks.
@RahulD
Hi Rahul,
Please find the mapping below.
"mappings": {
  "sample" : {
    "_all" : {
      "enabled": false
    "dynamic" : "strict",
    "properties" : {
      "nested_doc_name_xyz" : {
        "type" : "nested",
        "properties" : {
          "not_analyzed_field_name_xyz" : {
            "type" : "string",
            "index" : "not_analyzed",
            "doc_values": true
The query you suggested still might not work since as I mentioned earlier, for a document which has the following value
           "ABCD",
           "1234",
the following query
must_not": {
  "term": {
returns true. But I am looking for a query which returns true ONLY when the value for the field's value is just "".
for example,
It has an empty string ("") as the only constituent. This document should be true whereas
           "ABCD",
           "1234",
This should be false
