So, I am a bit (ok more than a bit) of a newbie. We are using ELK for
collecting storing logs, and recently we started seeing these errors:
[FIELDDATA] New used memory 2570680025 [2.3gb] from field [@timestamp]
would be larger than configured breaker
I am using (more or less) the standard logstash template:
"allstash" : {
"order" : 0,
"template" : "stash-",
"settings" : {
"index.refresh_interval" : "5s"
"mappings" : {
"default" : {
"dynamic_templates" : [ {
"message_field" : {
"mapping" : {
"index" : "analyzed",
"omit_norms" : true,
"type" : "string"
"match" : "message",
"match_mapping_type" : "string"
"string_fields" : {
"mapping" : {
"type" : "string",
"fields" : {
"raw" : {
"index" : "not_analyzed",
"ignore_above" : 256,
"type" : "string"
"match" : "*",
"properties" : {
"geoip" : {
"dynamic" : true,
"path" : "full",
"properties" : {
"location" : {
"type" : "geo_point"
"type" : "object"
"@version" : {
"type" : "string"
"_all" : {
"enabled" : true
"aliases" : { }
I am assuming that I should be using Doc Value for the @timestamp field?
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/f643a1a3-d795-470a-b32f-310a707e0015%40googlegroups.com.
