Create a multi metric machine learning job using dev tools
I want to create a multi metric ml job that will be expired in 1d. Can I do it using dev tools?
I have created a forecast job like so and now I want to create a ml job.
My Forecast job:
POST _xpack/ml/anomaly_detectors/forecast_manually/_forecast
"duration": "56d",
"expires_in": "1d"
Thank you very much in advance!
/Angelos
Hi Angelos,
See the API for creating an anomaly detection job. Jobs don't have an expiration date inherently because in general, one normally runs ML anomaly detection jobs on-going. You would have to manually delete a job if you were done with it.
Thank you very Rich!
