Create index pattern (for system metrics module)
Issue: Not able to Create the Index Pattern for metricbeat in Kibana.
Steps:
  1. I installed Elasticsearch, Kibana and Beats as per the documentation. Started the Metribeat service.
  2. updated the metribeat.yml as per the suggestions
  3. Metricbeat index is available in elasticsearch but not able to create the Pattern for the same in Kibana
Please help.1 3
The index pattern should have been created for you when you ran the setup command. Did you see any errors in your console when you ran it? What version of ES/Kibana/Beats are you running?
