Create index with index-settings
We are trying to migrate from Elasticsearch 6.7.1 to Elasticsearch 8.2.0.
In Elasticsearch 6.7.1 it was possible to provide index-settings within an CreateIndexRequest as follows
    "index": {
      "mapping": {
        "total_fields": {
          "limit": 4000
In Elasticsearch 8.2.0 it produces the following error
Exception in thread "main" co.elastic.clients.json.JsonpMappingException: Error deserializing co.elastic.clients.elasticsearch.indices.IndexSettings: Unknown field 'mapping' (JSON path: index.mapping) (line no=3, column no=16, offset=34)
	at co.elastic.clients.json.ObjectDeserializer.parseUnknownField(ObjectDeserializer.java:221)
	at co.elastic.clients.json.ObjectDeserializer.deserialize(ObjectDeserializer.java:178)
	at co.elastic.clients.json.ObjectDeserializer.deserialize(ObjectDeserializer.java:136)
	at co.elastic.clients.json.JsonpDeserializer.deserialize(JsonpDeserializer.java:75)
	at co.elastic.clients.json.ObjectBuilderDeserializer.deserialize(ObjectBuilderDeserializer.java:79)
	at co.elastic.clients.json.DelegatingDeserializer$SameType.deserialize(DelegatingDeserializer.java:43)
	at co.elastic.clients.json.ObjectDeserializer$FieldObjectDeserializer.deserialize(ObjectDeserializer.java:71)
	at co.elastic.clients.json.ObjectDeserializer.deserialize(ObjectDeserializer.java:180)
	at co.elastic.clients.util.WithJsonObjectBuilderBase.withJson(WithJsonObjectBuilderBase.java:66)
	at co.elastic.clients.json.WithJson.withJson(WithJson.java:57)
As workaround i tried to set the index.mapping.total_fields.limit via the JAVA API Client via
builder.mappings(  m -> m.totalFields( totalFields -> totalFields.limit( 4000 ) ));
but it also produces an error
co.elastic.clients.elasticsearch._types.ElasticsearchException: [es/indices.create] failed: [illegal_argument_exception] unknown setting [index.mappings.total_fields.limit] did you mean any of [index.mapping.total_fields.limit, index.mapping.nested_fields.limit, index.mapping.dimension_fields.limit]?
	at co.elastic.clients.transport.rest_client.RestClientTransport.getHighLevelResponse(RestClientTransport.java:281) ~[elasticsearch-java-8.2.0.jar:?]
	at co.elastic.clients.transport.rest_client.RestClientTransport.performRequest(RestClientTransport.java:147) ~[elasticsearch-java-8.2.0.jar:?]
	at co.elastic.clients.elasticsearch.indices.ElasticsearchIndicesClient.create(ElasticsearchIndicesClient.java:266) ~[elasticsearch-java-8.2.0.jar:?]
So how can i set value of index.mapping.total_fields.limit within an CreateIndexRequest?
Elasticsearch 6.7.1 is EOL and no longer supported. Please upgrade ASAP.
(This is an automated response from your friendly Elastic bot. Please report this post if you have any suggestions or concerns :elasticheart: )
Hi Alexander! It is happening to me also. It seems clearly to be a bug
