Difference between should clause with minimum_should_match and should clause inside a must clause
Hello everyone,
I'm doing a request using should and filter clauses like this
GET case/_search
  "_source": false,
    "bool": {
      "should": [
          "multi_match": {
            "query": "france",
            "fields": [
              "translations.en.title",
              "translations.en.title2"
          "nested": {
            "path": "nested_articles",
              "multi_match": {
                "query": "france",
                "fields": [
                  "nested_articles.level_title",
                  "nested_articles.article_title.",
      "filter": {
        "range": {
          "adoption_date": {
            "lte": "2013-03-21T23:00:00.000Z"
After doing some research, i found out that if i put filter clause with should clause like above, should clause became optional and elasticsearch returns the result matched the filter clause, regardless should clause
That is when i came up with two solutions.
The first one is putting should clause inside a must clause, and then combine this must clause with filter clause (like bellow)
GET case/_search
    "bool": {
      "must": {
        "bool": {
          "should": [
              "multi_match": {
                "query": "france",
                "fields": [
              "nested": {
                  "multi_match": {
                    "query": "france",
                    "fields": [
                      "nested_articles.level_title.en",
                      "nested_articles.article_title.en",
                      "nested_articles.content.en"
      "filter": {
        "range": {
          "adoption_date": {
            "lte": "2020-03-21T23:00:00.000Z"
The secoud one is using minimum_should_match, in this case is 1 (like bellow)
GET case/_search
    "bool": {
      "must": {
        "bool": {
          "should": [
              "multi_match": {
                "query": "france",
                "fields": [
              "nested": {
                  "multi_match": {
                    "query": "france",
                    "fields": [
      "filter": {
        "range": {
          "adoption_date": {
      "minimum_should_match": 1
The number of results was returned is differents. The first solution has 124 hits and the second one has 122 hits.
What is the difference between these two query ?
Are there any better solution than these two solution above ?
Thank you in advance for your answer.
anyone, pls help me
