Do I need to convert fields in logstash if I have a index template in elastic?
Hi, I've been converting some fields in logstash, but I was wondering if I really need to do this if I have a index template with those fields already created in elastic
      mutate {
        convert => {
                "value" => "float"
                "hostid" => "integer"
in index template:
      "value": {
        "type": "float"
      "hostid": {
        "type": "long"
I do not believe you do. elasticsearch will attempt to parse the field according to the template.
