I’m trying to do a search on multiple fields in collection. This is what I tried. How do I fix this?
search_query = { "query": { "match": { "RunID": RunID, "host": host_name } } }
Hey there @HaroldMelamed and welcome to the community! You may want to check out our multi-match query, that should get you what you want for the same search string. Or a boolean query for multiple terms. Happy searching!
what I’m looking for is to search two different fields in a single query with different search criteria. For example
(runID = 12324 and host = LRE)
@Kathleen_DeRusso gave you the correct answer using a bool
"bool" : {
"must" : {
"term" : { "runID" : "12324" },
"term" : { "host" : "LRE" }
Thank you very much the exact query. I need even the most basic help these days. At my age it appears that my brain is full . ![]()
All good ... Many of the free LLMs are a great place to start with helping to write queries.
here at the bank we aren’t doing AI yet. They promised soon. Thanks for the idea!!
The code works but VSCODE isn’t appreciative of the code.
search_query = { "query": { "bool": { "must": { "term": {"runID": RunID}, "term": {"host": host_name} } } } }
If you look at the API docs for the bool query linked above, I think you’re missing some { } to denote objects in json for each term query.
Working Example ... sorry I wrote that first one on my phone
You need the array bracket [ ]
If you Go into Kibana Dev Tools, the Smart Editor will help with all that..
If you are trying to write DSL outside of that, you will likely make many mistakes ![]()
POST my_index/_doc
"foo" : "fooish",
"bar" : "barish"
POST my_index/_doc
"foo" : "fooish",
"bar" : "notbarish"
GET my_index/_search
"bool": {
"must": [
"term": {
"foo": "fooish"
"term": {
"bar": "barish"
