Elascicsearch was running in mbp m1 pro much slower than intel platform
I just got a mbp m1 pro .And I found that using es 7.15.2 , in my think pad I just can complete my procedure in just 3 minuts . The contents of procedure is just writing index data to es.But I installed es 7.15.2 and running the same java procedure ,it used 16 minites...
Oh , I found the reason . The reason is that I should use jdk for arm 64-bit. See this :https://www.winsonlo.com/it/howto/zulu-jdk8-on-m1/
I think that the jdk is provided within the distribution so you don't have à bring your own one.
