Elasticsearch: Automatically setting index level settings for daily indexes
I need to increase the,
  • maximum value of documents retrieved by an Elasticsearch query
  • maximum number of script_fields that are allowed in a query
After refering this, I used the update-index-settings API as below, for the above tasks.
  • To increase maximum value of documents
PUT _all/_settings {
"index" : { "max_result_window" : 20000 }
  • To increase maximum value of script_fields
"index" : { "max_script_fields" : 40 }
Even though they get applied for all the current indexes, the settings do not get applied to any new index created in Elasticsearch. I have daily indexes getting created and I would like to know if there's a way to automatically set the above settings for any new index created in Elasticsearch.
Your kind help would be appreciated. :blush:
You need to create a template that will be applied to your index when it is created.
The documentation about index templates is here.
Thank you so much for the quick response @leandrojmp! :blush:
I will try it out.
