Dear all:
Recently I come across a strange problem. I want to use the
elasticsearch-1.0.0 as a backend storage for hive. I use the
elasticsearch-hadoop-1.3.0.M2 to create hive tables on elasticsearch. The
hive sql are as followings:
create external table supplier_es (S_SUPPKEY BIGINT, S_NAME STRING,
S_ADDRESS STRING, S_NATIONKEY BIGINT, S_PHONE STRING, S_ACCTBAL DOUBLE,
S_COMMENT STRING) stored by
'org.elasticsearch.hadoop.hive.EsStorageHandler'
TBLPROPERTIES('es.resource'='q9/supplier','es.index.auto.create'='true','es.nodes'
= 'localhost:9200');
create external table nation_es (N_NATIONKEY BIGINT, N_NAME STRING,
N_REGIONKEY BIGINT, N_COMMENT STRING) stored by
TBLPROPERTIES('es.resource'='q9/nation','es.index.auto.create'='true','es.nodes'
The table mapJoin operation is as followings:
select s_suppkey, n_name from supplier_es s join nation_es n on
n.n_nationkey = s.s_nationkey;
The above hive sql can't run successfully, I have try to figure out the
problem, but I can't find out the reason. I ask anyone for help. Thanks
very much. The error messages( I get from the log file):
2014-03-19 15:16:39,447 INFO [main]
org.apache.hadoop.conf.Configuration.deprecation: map.input.file is
deprecated. Instead, use mapreduce.map.input.file
2014-03-19 15:16:39,448 INFO [main]
org.apache.hadoop.hive.ql.exec.MapOperator:
fpath:hdfs://server-220:8020/user/hive/warehouse/nation_es
2014-03-19 15:16:39,462 INFO [main]
org.apache.hadoop.hive.ql.exec.MapOperator: getPathToAliases
2014-03-19 15:16:39,463 INFO [main]
org.apache.hadoop.hive.ql.exec.MapOperator: Adding alias s to work list for
file hdfs://server-220:8020/user/hive/warehouse/supplier_es
2014-03-19 15:16:39,465 ERROR [main]
org.apache.hadoop.hive.ql.exec.MapOperator: Configuration does not have any
alias for path: hdfs://server-220:8020/user/hive/warehouse/nation_es
2014-03-19 15:16:39,480 WARN [main] org.apache.hadoop.mapred.YarnChild:
Exception running child : java.lang.RuntimeException: Error in configuring
object
at
org.apache.hadoop.util.ReflectionUtils.setJobConf(ReflectionUtils.java:109)
at org.apache.hadoop.util.ReflectionUtils.setConf(ReflectionUtils.java:75)
at
org.apache.hadoop.util.ReflectionUtils.newInstance(ReflectionUtils.java:133)
at
org.apache.hadoop.mapred.MapTask.runOldMapper_aroundBody2(MapTask.java:434)
at org.apache.hadoop.mapred.MapTask$AjcClosure3.run(MapTask.java:1)
at org.aspectj.runtime.reflect.JoinPointImpl.proceed(JoinPointImpl.java:149)
at org.apache.hadoop.mapred.YarnChild.main(YarnChild.java:158)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at
org.apache.hadoop.util.ReflectionUtils.setJobConf(ReflectionUtils.java:106)
... 19 more
Caused by: java.lang.RuntimeException: Error in configuring object
at
at
at org.apache.hadoop.mapred.MapRunner.configure(MapRunner.java:38)
... 24 more
at
at
at
... 27 more
Caused by: java.lang.RuntimeException: Map operator initialization failed
at
org.apache.hadoop.hive.ql.exec.mr.ExecMapper.configure(ExecMapper.java:142)
... 32 more
Caused by: org.apache.hadoop.hive.ql.metadata.HiveException:
org.apache.hadoop.hive.ql.metadata.HiveException: Configuration and input
path are inconsistent
at
org.apache.hadoop.hive.ql.exec.MapOperator.setChildren(MapOperator.java:419)
at
org.apache.hadoop.hive.ql.exec.mr.ExecMapper.configure(ExecMapper.java:110)
... 32 more
Caused by: org.apache.hadoop.hive.ql.metadata.HiveException: Configuration
and input path are inconsistent
at
org.apache.hadoop.hive.ql.exec.MapOperator.setChildren(MapOperator.java:413)
... 33 more
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/290fd063-6a2d-465c-9d4e-8382ec0db7a9%40googlegroups.com.
