Hello.
I am trying to test if the field is a valid IP address. If not, I want to remove it.
I also stick to the ECS convention.
My ingest pipeline:
PUT _ingest/pipeline/ingestion_pipeline_geo
"description": "geoenrichment",
"processors": [
"dot_expander": {
"field": "host.ip",
"ignore_failure": true
"grok": {
"field": "host.ip",
"patterns": [
"^%{IP:host.ip}$"
"on_failure": [
"remove": {
"field": "host.ip",
"ignore_failure": true,
"ignore_missing": true
My data:
PUT my_index/_doc/1?pipeline=ingestion_pipeline_geo
"host.ip": "1.2.3.433",
"host.name": "h0012",
"host.id": "prod server"
My result:
GET my_index/_doc/1
"_index" : "my_index",
"_type" : "_doc",
"_id" : "1",
"_version" : 13,
"_seq_no" : 12,
"_primary_term" : 1,
"found" : true,
"_source" : {
"host" : { },
"host.name" : "h0012",
"host.id" : "prod server"
When the IP is valid all works fine:
PUT my_index/_doc/2?pipeline=ingestion_pipeline_geo
"host.ip": "1.2.3.42",
GET my_index/_doc/2
"_type" : "_doc",
"_id" : "2",
"_version" : 1,
"_seq_no" : 13,
"found" : true,
"_source" : {
"host" : {
"ip" : "1.2.3.42"
Why I do fail to remove the field host.ip and being left with the "host": {}?
Is there any other workaround than removing "host" in the on_failure section? (Which is not accurate tbh). eg.
"processors": [
"dot_expander": {
"field": "host.ip",
"grok": {
"field": "host.ip",
"patterns": [
"^%{IP:host.ip}$"
"on_failure": [
"remove": {
"field": "host",
"host.ip": "1.2.3.42s",
GET my_index/_doc/2
"_type" : "_doc",
"_id" : "2",
"_version" : 2,
"_seq_no" : 14,
"found" : true,
"_source" : {
Observed behavior is on ES 7.2.0.
Thanks for any hints.
